Page 1 of 3 123 LastLast
Results 1 to 20 of 74
    Dec 2007
    For those of use that like more than a simple warning light especially for use diesel owners that add boost or push there turbo charged vehicle hard.
    I run Nordskog gauges, they don't make them anymore but they are some of the best gauges for the money, I got them on a surplus sale since Nordskog went out of business . Got extras since they were a great deal.
    Got a volt meter, a must in my opinion in a tropical climate since batteries love to give out without warning, It's nice to have early warning instead of a clicking noise when you turn the key.
    Boost Gauge since I run more than stock boost and have a manual boost controller it's pretty much mandatory.
    Autometer Pyrometer/exhaust gas temp gauge. Also a must for any turbo diesel owner. Don't really like the autometer non through gauge lighting so I will replace it later.
    And last for now my hour meter for my secondary injection systems.
    Still waiting to install my oil and water temp gauges and oil pressure gauge when I get back to the Philippines.
    I switched all the bulbs with LED's still trying to decide if I want to keep the blue or go with green since green matches the stock gauges better. Plus using LED's you use a lot less power and don't have to worry about blown fuses using a single 10amp source. The gauge pod was burning hot with the standard bulbs.
    Jul 2011
    ganda namn... wala kaseng tachometer yung pregio ko.. saan kaya pede palagyang tachometr yung pregio ko near muntinlupa area sana..padagdagan ko na rin sana ng voltmeter..
    feeling ko iyong mga a/t na auto kelangan talaga ng volt meter. iyong gd namin at iyong fd mga twice na napunta sa alanganin kasi na-dedo na ang battery
    would it be easy to install volt meters on those cars? how much does it cost anyway and where in the south would it be ok to have it installed? although i love doing diy, i think this will be out of my league considering most everything w/ those cars are electronic. now if it's going to be done on my ek, i can probably install it myself given the correct data to refer to
    Jul 2011
    manual ba ndi na kailangan? 2004 pa kase yung pregio ko at newbie kase ako sa sasakyan kaya much better meron akong indicators na imomonitor ;)
    ^ so those volt meters inserted to cig lighters thingies aren't accurate? but i guess that'll do since i've been told that doing a diy on these stuff aren't that advisable
    gtamp: kailangan din naman pero kasi pwede naman ma-kadyot start ang m/t kung kinakailangan. ang a/t walang tulak tulak kaya talagang yari ka unless may jumper cables ka parati dala. hassle nga lang iyong mag-hahanap ka ng kakabitan ng cables kung wala ka sa lugar niyo
    Feb 2012
    hindi siya accurate kapag gantong circumstance.in my case, AT kasi siya, when put into drive bumaba menor, tapos sabay pa lights and AC, tendency bumababa karga ng alternator.. sa volt meter ko sa cabin(which is ung asa lighter nga), 11.something to 12.sumthing, pero dun sa volt meter talaga na direct sa battery, consistent 12+ naman siya, yun lang naman ung discrepancy sir.. when put into neutral or kapag inapakan ung gas almost the same naman..
    Quote Originally Posted by gearhead000 View Post
    If you put in over the counter bare LED's, then you will need not just resistors but probably bulb adapters also. There are now exact replacement LED's for almost every type of bulbs that are just "plug and play".
    any idea sir kung saan makaka kuha ng high quality LEDs? pero un reasonable naman price, thanks!
    Jan 2009
    Quote Originally Posted by EA622 View Post
    The symptoms you described are caused by voltage loss across the vehicle wiring when accessories are pulling a lot of current (ie. lights). You can verify this by measuring the cigarette lighter voltage using a proper tester and comparing it with the voltage taken from the battery posts.
    This is one reason why some people use grounding kits and/or increase the wire diameter of the positive cable.
    Feb 2012
    my volt meter is like ths one
    Though, it has some discrepancies when compared to a real volt meter..
    what is a manual boost controller? and where did you get your LED bulbs sir?
    i need these kind of LED bulbs for the gauges, thanks!
    Feb 2012
    eto ang solusyon sa dead battery emergency situation: CDR KING Car Power Mini-Jumper
    May 2009
    i usually check on weekends the output of the alternator using a digital multimeter while my gage is not yet installed.
    the alternator idiot light actually lives up to its name...does not light up when the alternator is overcharging and undercharging down to 9V.
    Oct 2011
    Sir, how doest it work? may charge capacity yan needed for the extra boost?
    May 2009
    [QUOTE=dvldoc;1678831
    I switched all the bulbs with LED's still trying to decide if I want to keep the blue or go with green since green matches the stock gauges better. Plus using LED's you use a lot less power and don't have to worry about blown fuses using a single 10amp source. The gauge pod was burning hot with the standard bulbs.[/QUOTE]
    some questions doc,
    1. what's the hour meter (secondary injection systems??). how does it compare to an engine hourmeter? i'm actually interested in an engine hour meter for a diesel.
    2. Is it safe if i tap my analog voltmeter (mine's just like yours but a cheaper one) on the cigarette lighter outlet? i mean not a parallel wiring via the main ignition switch.
    3. What are the things to do if changing from standard bulbs to LED? i read an article that you need resistors to keep the LED from blowing. can't remember exactly
    TIA
    Dec 2007
    Quote Originally Posted by miked View Post
    some questions doc,
    TIA
    My hour meter is something none of you will need, it just activates with my LPG injection and lets me know how long a tank last, It's tied in to a pressure switch which only turns it on when the LPG is injecting.
    A volt meter is easy to install you just need to power it with a ignition on positive source and ground it, The same way you would hook up a automotive bulb. Or your radio.
    The best way is tap a source in the fuse box, if you don't want to pull out your radio.
    LED bulbs are just a option, I only changed mine because I wanted a different color and they last basically forever and make less heat. You don't need a resistor on newer LED bulbs.
    Manual boost controller is a bleed valve device hooked to your turbo that lets you dial in what boost level you want.
    I have 2 more of those volt meters I use sitting around, But won't be back in the country till July. Hit me up then if you want one. My are Nordskog Vicking series, they are full metal bodys with powder coated exterior, real glass lenses that are UV sealed, and the gauge has all brass and copper internals. It's ment to use in a salt water enviorment so will last forever and look good for life.
    Jan 2009
    Digital gauges on my ScanGaugeII. Not as elegant as an analog dial but it gets the job done, and then some.
    Aug 2006
    mga paps, tanong ko lang kung may alam kayo installer ng sandwich plate para sa civic sir meron na kasi akong guages pro wala pa installer thanks
    anyone knows where can i get the T fittings for the boost gauge?
    and for the gauge pod, sa audio stores lang ba meron or any shop naman in banawe?
    thanks!
    May 2009
    thanks!
    hardware stores din
    Dec 2007
    nakakita ako ng ganito sa net using obd2 port
    -- Speed (km), Rpm, Water temp, Battery Volt
    tapos eto naman scan guage na mas marami options
    may nakasubok na ba sa inyo at saan kaya meron dito sa pinas?
    Jul 2010
    Updated version of my DIY Gauge for Mitsubishi Lancer Itlog
    Tachometer, Audible Coolant Overheat Alarm and LED Graph Battery Level Indicator.
    Attached Thumbnails Attached Thumbnails diytachometeroverheatalarmbarledbatterylevelindicator_zpsf8937ff2.jpg
    May 2009
    Quote Originally Posted by Chinoi View Post
    nice one brader....maaari mo rin bang ishare yang DIY mo on a step by step basis...para magaya din sana....salamat
Let's see your gauges
