Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 74
    Jun 2011
    #41
    Check mo muna, alam ko hindi pa obd standard ang diagnostic port ng mb100. Ni hindi ata obd1. Hehe
    sir para sa ford
    #42
    sir para sa ford
    Try mo muna sir. Sa tsikot.com store pwede ata subukan. Hehe. Pm niyo po si jedi.
    May 2012
    #43
    Down ang CDR-King website. So I went to CDR-King's Visayas Ave. branch last night to see if they offer an OBD2 scanner. Waited in line for 50 minutes to learn wala sila nung thingamajig na yun and didn't even know what that "carplug" was for. Effin stupid system they have... they could just have a product list available for buyers to browse through, instead of making us wait so long just to talk to a salesperson, na ayaw naman mamansin kung di mo pa number/turn...
    #44
    ^ may instance pa na sasabihan ka ng wala o walang stock pero meron palang display
    inefficient system and staff
    Feb 2012
    #45
    mga paps pa o.t lang, paano po wirings ng ganitong amp guage ?
    #46
    Quote Originally Posted by sotel View Post
    it is normally used to show charging current ... so it should be wired in series with the output of alternator ... take note of the polarity to show positive reading when the alternator is actually charging the battery and the wire used is as thick as the alternator's output wire
    Feb 2012
    #47
    Quote Originally Posted by kinyo View Post
    paps bat may nakalagay sa likod niya na negative at positive?
    Jan 2009
    #48
    That's correct.
    Remember to put the ammeter in SERIES. If you have to ask that question, you don't know the basics and you should just have it done professionally.
    If you plug in that ammeter to the positive and negative posts of the battery... KABOOM!!
    Sep 2011
    #49
    Aug 2006
    #50
    mga paps, tanong ko lang kung may alam kayo installer ng sandwich plate para sa civic sir meron na kasi akong guages pro wala pa installer thanks
    #51
    anyone knows where can i get the T fittings for the boost gauge?
    and for the gauge pod, sa audio stores lang ba meron or any shop naman in banawe?
    thanks!
    May 2009
    #52
    thanks!
    hardware stores din
    #53
    Quote Originally Posted by miked View Post
    hardware stores din
    Ok sir. Hanap nalang ako sa hardware ng copper T fittings. How about the hoses? May special hose ba or hydraulic hose ok na?
    #54
    CB, kasama yung T fittings at hose pag bili mo ng boost gauge. I don't think na makakabili ka ng copper T fitting masyadong maliit yung dia, pwede yung push connector na 4mm. Yung hose niya ay 4 mm na PE.
    #55
    Nelany, Saan ako makakahanap ng push connector?
    Im looking for a place to put the boost gauge pa. Im thinking of putting in dun sa 1 din pocket just below the radio. Parang block off plate na
    #56
    Gamit sa pneumatic machine so doon ka makaka bili ng push connector at nung hose. Normally yung gauges ay sa pillar o sa ibabaw ng dash nilalagay para kita mo sa front mo.
    #57
    I checked the hose of my boost gauge and it is 6 mm and not 4 mm.
    May 2009
    #58
    pwede mo rin siguro pwersahin para kapit talaba. remember, boost yan hindi vacuum. ang tendency eh matanggal under boost. hehe
    btw, plastic lamang yung t-fitting na kasama dun sa binili ko boost gage (with boost hose na rin). cheap Circuit brand lang. so far, buhay pa naman yung gage.
    Dec 2009
    #59
    im also using circuit boost gauge.. ok naman... naka overboost pa ako minsan at 1.1 bar.. hahaha... the fittings and tubings included can also hold up... 2 years na ok parin...
    i just use springs to delay the wastegate opening...
    #60
    Quote Originally Posted by miko101130 View Post
    Just use the push connnector na T walang kawala yan maski anong lakas na boost.
Let's see your gauges
