sino na may electronic oil pressure gage dito? kahit yung circuit brand lang. yung pressure sender na lang hinahanap ko eh. may gage na suking tindahan ko kaso di ko pa kinuha dahil wala naman yung sender. di pako makapunta punta manila area eh.
^try mo dito bro
http://www.**************/index.php/...=circuit+gauge
anybody who tried using a full length of rubber hose for the oil pressure gage (mechanical)? siguro in my application about 2.5 meters ang haba. hindi kaya apektado yung readings sa gage kung full length ay rubber at wala nang steel tubing coming from the oil tap? what i usually see eh steel/copper tubing from engine then the rubber hose to the gage
kung hindi matuloy yung oil electrical gage ko eh mechanical na lang. either from the tee-fitting sa stock location or a tee-fitting from the turbo oil supply line coming off the cylinder head.
Replaced my SGII with this awesomeness!
Page 1/7
Page 2/7
Page 3/7
Page 4/7
Pages 5 to 7 are still empty and I haven't given it much time to set them up. I'm probably using anywhere between 1/3 to 1/2 of all the available gauges. Some are not that essential, but more of a nice to have.
One good thing about the UltraGauge is that, it can show up to twice as many gauges on a single page (8) compared to the SGII (4).
Cabin thermometer is php199 from concorde. Sa sm manila at greenhills branch ako nakabili. Meron dn sa japan home 88 pero medyo jologs. Kinabit ko sa urvan ambulance.
Voltmeter kahit saan meron niyan. Pm mo si niwde11 dito or sa suking auto supply. 400 yun gauge, 300 ata yun bahay. Yung install mga 200 to 300 if ipagagawa mo sa shop. I had mine done at the usual place of Jorge and Jemson pero si Pony nagkabit.
with a cheap chinese obd2 bluetooth adapter and a cheap (but incredibly useful!) android app, plus not-so-cheap Galaxy Tab ... you can have all the gauges you want
less than US$20 sa amazon at yung app less than 200 petot lamang sa android markethow much is the cheap chinese obd2 bluetooth adapter?
sa OBD2 port ng sasakyan kadalasan makikita under dash malapit sa kaliwang tuhod ng driver for LHDat san po yan ikakabit?
opo basta meron ODB2 port and sasakyan (1996+ models)pwede ba yan sa gas and diesel engine?
Check mo muna, alam ko hindi pa obd standard ang diagnostic port ng mb100. Ni hindi ata obd1. Hehe
true Doc Otep ... yung starex 2002 TCI namin meron obd connector pero hindi obd2 compliant, i was told the connector is only used for programming the immobiliser
although obd2 implementation started in 1996, not all makers complied for many years ... today, it is believed that all cars since 2005 are obd2 compliant (at least in first world countries! lolz) ... ewan lang dito sa pinas![]()
^ thanks bro!
btw the adapter also works on my little Galaxy Y phone ... sana lang matibay ito ... china-made eh, nakakaduda, presyong cdrking!
