Page 3 of 21 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 629
    May 2011
    Dalhin mo kay jemson. The immobilizer on my patrol still works naman even after he added a turbo timer and alarm system.
    May mga installers talaga na hindi gano sure sa ginagawa nila kaya kahit mag offer ng free install yung pinagbibilan ko ng parts eh mas gusto ko pang magbayad na lang ke jemson,
    Just like one of the previous posts in this thread. Hindi makabitan nung unang installer ng alarm yung Foton and sinisi pa ata yung brand. Nung ginawa ni jemson, wala naman daw pinag iba sa japanese car yung wiring.
    OTEP, this is the same experience that I got with 3 installers, masyadong bago daw yung design ng FOTON. KAya daw gawin, pero papatayin yung auto retract feature ng bintana. Di ako pumayag patayin kasi sayang naman yun, so what they did was install a separate actuator. Ang problema ngayon ng alarm ko, di na yata gumagana yung actuator, kaya balik manual ng pag lock ako (via the key), tapos engage the alarm para pag may force entry, tutunog. Isa pang flaw sa pagkakakabit eh yung pag tapak ko sa brake, yung door ko lang nag auauto lock, yung iba di sumasara kaya pipindutin ko pa yung lock sa tabi ko para mag close lahat ng door.
    I am planning to bring it kay jemson para maayos pagkakagawa, medyo sablay eh.
    Mar 2012
    Sir Otep, regarding turbotimer....what brand do you recommend to work with my current 'code alarm' (2005 fieldmaster). Do I need to look for a specific feature of a turbo timer? Worry ko kasi baka hindi maactivate yung alarm after mamatay yung makina. Papakabit sana ako kay jemson. TIA
    Ibalik mo lang sir. Di naman pahirapan ang back job dun. At least in my experience. May isa kasing shop diyan in the area, kinailangan pa magpatawag ng pulis ng insan ko para lang sa backjob. Sounds like a module problem sir since sumasara pa yun pinto when you hit the brakes.
    May 2011
    Ayoko na ibalik for a back job boss, I'd rather spend an extra with Jemson pero sigurado naman na kaya gawin. I bet he can incorporate properly the G-Force alarm system with the current cetral locking of foton. Siguro after the holy week daan ako sa kanya. Same number pa rin naman gamit nya noh?
    Yes same number po. Nabanggit ko na yung problem mo sa kanya kanina when I asked if open sila bukas. Idaan niyo lang daw po. Pero best to call before coming para andun siya..
    May 2011
    Wow, thanks a lot doc otep! Will definitely give him a call.
    Ok na ko dun sa mga Thai brand ni c3 4x4 along araneta. Nothing fancy. Pure timer na sinlaki lang ng isang dashboard switch blank. Ang mas important ay yung installer po.
    Nag EB pala mga nissan patrol boys sa shop kanina. Di ako nakapunta.
    Volution ata yung brand sa c3. I forgot the other one. We ise both brands on different vehicles. Ok naman.
    New service. Carbon fiber decal for your worn/faded window visors.
    May 2011
    Update! I went to Jemson's shop the other day and unfortunately, he confirmed that iba nga daw yung setup ng module ng foton. So his solution was to install actuators on all four doors para yung features ng auto window riser eh hindi magagalaw. I'll be coming back para install yung actuators.
    Mar 2012
    Yes, I have seen those turbo timer na maliit and parang switch din ang dating... mukang ok nga ito since parang OEM ang dating kung sa may blank switch plate ang kabit. I hope this works with car alarm.
    Nagiinstall ba sila sa intercooler hood scoop ng Fieldmaster? I tried DIY dati, hindi ko makuha yung curve ng scoop, nasira yung carbon fiber, hehe. And how much cost for these visors?
    Tanong ko na rin if Jemson can repair the air duct selector switch ng pajero? I might buy a unit kaya lang parang hindi nagfafunction yung switch...walang change sa labas ng hangin e sa mga air duct. I want to know if simple lang ito before we get the unit.
    TIA!
    Thanks
    If you want less expensive actuators, you can order them from roman lao of sulit.com . PHp500 for a set of four already. Installed a set on the urvan. =)
    He even delivers for free if you dont live so far from him. Mas mahal ang actuators kina jemson. Normal shop mark up i guess.
    May 2011
    Kaso I don't have the harness eh, so I guess no choice but to go with him. Ok na yun, at least I can go to him pag nagkaroon ng problem.
    500 ata sa visor. Sa hoodscoop baka cheaper? Proto po or mong yung gumagawa.
    Di ko po sure sa duct selector sir
    Sir, its a boxed set with the wires and module included po. Si jemson din nagkabit for me.
    just came from Jemson's. he's a bit busy with the Metro Rescue hehe will probably go back tom nalang. saw doc Otep's LC there also. and in Kaingin road this afternoon hehe
    would like to know if the power window motor is repairable? mine has intermittent power e. minsan pwede minsan ayaw naman.
    Hello. Si jorge po gumagawa ng Metro Rescue. Sobrang busy nga today, ni hindi nagawa ni Jemson yung papagawa ko sa cruiser. Oh well, at least it was fun watching the work done on the other vehicles there.
    What time po kayo nadaan and what vehicle po?
    Yep, repairable po. They repaired mine dati and yung sa orange crosswind po kanina.
    doc, ako yung nagpakabit ng projectors dati na fieldmaster hehe dumaan ako ng 7pm. parang may ginagawa siya metro rescue, from underneath yata? hehe i will drop by tom morning to have him check the power windows. hopefully ma-repair pa. intermittent power kasi.
    Ah yes, nakita po namin kayo dumaan. May inayos lang siya sa Aux fan sa ilalim (one of 3 in an Urvan) after Jorge finished the radiator.
    Ito po siguro ang eksanang inabutan niyo kanina:
    Jorge working on the radiator:
    hopefully ma-repair pa ni jemson yung power window motor.
    doc, im thinking of adding an aux fan in the right side of the pajero's grill. this is where the tranny cooler is located. left side is the stock a/c aux fan. any suggestions for the brand of fan to use? yung malakas sana hehe to aid the cooling of the rad din during the middle of the day.
Jemson Thread [new number]
