Results 1 to 10 of 241
December 20th, 2005 10:22 AM #1
I was reading the October issue of Top Gear and i saw these items, and thought of installing it in my car.
Could you guys tell me the pros and cons of these?
Here are the short descriptions of these items.
RAIZIN VOLT STABILIZER BY PIVOT
cost: Php 3850
+Engine start easier
+ICE will sound better
GROUNDING WIRE KIT
cost: Php 1800
+Helps Efi engines run better by reinforcing the electrical system.
"To further improve car's electrical system combine the Raizin Volt Stabilizer with this grounding wire kit"
Worth getting or not?
I will install this in the Gen2 Crv.
- Mar 2005
- 703
December 20th, 2005 10:29 AM #2Unless 10 years > ang car mo, eh, I don't see the point of the volt stabilizer... yung grounding kit, pwede pa... pero mas mura yung 4-8 gauge sa hardware at i DIY na lang...
December 20th, 2005 01:47 PM #3
Parang mahal ang price ng grounding kit, ask Speedyfix, he sells grounding kits.
December 20th, 2005 02:43 PM #4
are these grounding kits and volt stabilizers really necessary? do car manufacturers recommend these?
city
December 20th, 2005 02:47 PM #5
They're not a necessity at all, as with ALL aftermarket parts.
You won't really improve on anything if your car is relatively new and stock. If you start upgrading other things like ignition, audio, etc, then your system will be able to function a little more efficient since it compensates for the additional load to the electrical system.
But the "correct" way of doing it is to upgrade your alternator to match the needs of your new power sapping upgrades along with a larger battery.
December 20th, 2005 04:38 PM #7
yah. un ground kits nasa P800 kuha ko with install..
un volt stabilizer na yan curious din ako hehehehe
January 9th, 2006 08:05 PM #9
where do you get your materials for DIY?
yung mura pero matino ha
type ko pala black color cables na medyo translucent
January 9th, 2006 08:12 PM #10
ang sabe sakin dati ng battery shop.. kuha ka lang ng isang makapal na wire tapos sa iground mosa boday ayos na daw.. though hinde ko ginawa.. nag kit parin ako
The backup charger finally arrived. Here are my findings and conclusion at the end:
