Results 11 to 14 of 14
- Apr 2009
- 1,902
September 23rd, 2010 09:08 AM #11
September 23rd, 2010 09:19 AM #12
4 year old spark plugs? kung iridium plugs pwede pa sigurong umabot ng ganun but I assume hindi iridium ang nakalagay sa inyo.
anyway, I suspect your distributor is damaged. here is my take..
1. change the whole distributor
2. change the high tension wires
3. change the plugs pleeeaase
no wonder bakit erratic ang idling niyo sir, your plugs might be full of deposits at hindi na maka-emit ng spark, in short pangit combustion, mahirap mag-start.
just start here sir, if you still stalled, you can post here again, I will try to diagnose your problems based on your post.
- Apr 2009
- 1,902
September 23rd, 2010 10:04 AM #13* sir ben, he even mentioned na wala na daw spark yung isang plug niya.
- Dec 2009
- 12
September 26th, 2010 01:13 AM #14Maganda po burn ng spark plug niya, bosch na platinum sya, saka quick start po sya before sya nagkaproblema, napalitan na namin distributor nya ng surplus, so far ok na sya ngayon
high idle RPM at engine start
