Results 21 to 40 of 42
    #21
    sir nagpalit knaba ng throttle body?
    Oct 2008
    #22
    When i still owned my optra, its throttlebody was replaced quite prematurely. maybe it was because i was loading gas from a gas station na medyo madumi na ang underground reservoir tanks.
    Mabuti na lang at free of charge pa yung total replacement during that time, bec naka warranty pa ang unit ko. then two or three years later, na one time big time din a ko when i needed to have the fuel pump replaced at GM - Libis.
    If you intend to keep your unit for a couple of years, i suggest you have your unit fixed with orig parts. but if you intend to sell it soon, other remedial measures suggested in this thread will do. i was planning to keep my unit longer, but when a good offer-price came, i sold it na!
    Sir larrysuerte/1D4LV, kumusta na po ang takbo ng optra ng business partner mo, na naka nissan sentra na fuel pump? can you please give us some feedback since mukhang naka halos half a year na ang unit, running with a nissan sentra fabricated fuel pump. para kung sucessful, others with the same problem, can start applying your remedy to solve their fuel pump problems. salamat po!
    #23
    *talarms, ok naman takbo ng oto nya ngayon, wala namang problema.
    Oct 2008
    #24
    Maraming salamat po Sir Larry sa feedback niyo!
    Calling on Optra owners who have similar problem with their unit's fuel pumps: A Series III Nissan Sentra Fuel Pump can work on the Optra. But this is something that should only be performed by a mechanic who knows what he or she is doing! After all, engine fuel is highly flammable, and on the other hand, a gas pump needs some electricity to power it!
    Optra Owners, goodluck & happy safe driving!!!
    #25
    Quote Originally Posted by talarms View Post
    bakit daw po pinalitan ung throttle body nyo?ano po mga symptoms ng sirang throttle body? Thanks...
    Aug 2009
    #26
    My 2006 Optra have trouble now. I need help.
    trouble: speed maintains 40KPH no problem but when it speeds up wala ng power. pag bumagal naman o huminto parang mamamatayan yung engine lalo na pag-naka aircon.
    Fuel Pump kaya po ito?
    #27
    I have the same problem. Itatry ko nga yang Fuel pump ng sentra. How much would it cost po kaya? E madali lang kaya maginstall nito? Thanks!
    Jun 2006
    #28
    picture naman ng fuel pump ng nissan sentra, side by side with the fuel pump with optra...
    how much iyun fuel pump ng nissan sentra?
    #29
    Quote Originally Posted by chuaed View Post
    uu nga sana may picture po. I still can't detect the problem of my optra. Ayaw kunin ng casa kasi overload na daw sila dun at walang parking sa chevy pasig.
    Jun 2006
    #30
    Quote Originally Posted by vncrlsoriano View Post
    bilhin mo nalang iyun fuel pump sa thunder, then dalhin mo nalang sa servitech or kay speedyfix.
    #31
    pero sure po kaya na fuel pump lang yun? Many thanks!
    Jun 2006
    #32
    may pang test sa chevy libis, kung okay pa iyun fuel pump, para malaman kung iyun talaga ang sira. sa akin nga madalang gamitin iyun fuel pump bumigay din... (naka-lpg kasi optra ko)
    #33
    Problem Solved! Nireplace ko yung mismong fuel pump lang hindi assembly. Pang nissan nga ata yung fuel pump na yun. And then nagstart na sya but yung menor nya e ayaw bumaba ng 2800 RPM. So I cleaned the throttle body pero ganun pa din. And what I did is we towed my car sa chevrolet libis and sabi ko dun sa service department na pakireprogram yung ECU/ECM(Computerbox) ng optra ko then ayun problem solved ok na ok na ulit sya.
    The thing is mahina din yung fuel pump ng optra and once na mareplace mo yun e kailangan pala magpareprogram. pero sometimes e hindi na kailangan.
    Apr 2009
    #34
    Hi to all!
    I had the same problem with my optra. what the mechanics did was-he advised me to replace the fuel pump motor. I bought it at P3K (replacement). Then umandar na nga sya. BUT na notice ko everytime na kakastart ko palang once tumakbo ako ng konte bago nagbreak ako then magggas hindi agad sya tumatakbo i have to wait for a while pa bago ule tumakbo...ano kaya gagawin ko??? dko naman po mabalik dun sa gas station kase mukhang hindi nila kabisado ung optra inabutan lang ako ng tirik near the gas station kaya dun ako nagpapalit bumili nalang ako ng fuel pump motor sa labas.
    1 more thing po..pinataas ko kc ung oto sa other gas station for body cleaing...my napansin po ako..sadya po bang my isang hose na hindi nakakabit dun sa my fuel tank? kc po nung pinaliptan sya ng fuel pump ibinababa nila ung tank mismo so hinugot lahat ng hose dun sa my isang black box on the right side na malapit sa gulong na connected sa my salinan ng gas. my 3 pong hose dun...ung dalawa nakakabit sa fuel tank mismo pero my isa po akong napansin na hindi nakakabit pero wala naman po nakita ung mekaniko na pedeng paglagyan unless nasa loob...cno po kaya sa inyo my alam kung para saan talaga un? or meant tlaga na hindi nakakabit???
    Salamat po kung my makakapagadvice saken:-)
    #35
    [quote=v6dreamer;1203615]2004 wow! a very short time.
    I cant tell you how long a fuel pump should last... but 15,00 just for the parts I dont know my friend I think its way too much for that price... that shouldnt be that expensive to replace.
    If you want you can do a little diagnose yourself. The fuel pump which pressurise the injectors is at the back of the car near the tank. It normally makes a quick 'buzz' ( so listen carefully) when the ignition is switched on, if it is working. There is also the fuel filter there which can get blocked.
    Finally try disconnecting the feed line to the injectors. Turn on the ignition.... fuel should pour out - TURN OFF QUICK!
    If no fuel coming out, no pump. You can check also the fuel pump relay maybe bad.[/quote
    sir,if i may ask ,madali bang palitan ang fuel filter,where is it located sir.
    #36
    V6dreamer!
    Thank you very much for your valuable advise! 'Pikit-mata' ko na lang ipina-replace ang fuel pump ng unit ko. Chevy Pasig me P11,000++ for the new fuel pump, from their original quote of P15,200++ They sent my defective fuel pump home with me, in a box. Till now, i don't know for sure if my pump was really beyond repair na. But when i did the 'quick buzz' test that you suggested, di na tumutunog ang old fuel pump ko. Wala naman akong technica na kaalaman sa makina. But the darn fuel pump is placed directly beneath the bench of the optra's rear seat. Thats also where my daughter's car seat is mounted. So i decided to bite the bullet, rather than risking anything worse!
    is it in the inside portion of the car,or outside the car,underneath the seat portion sir .?
    #37
    Quote Originally Posted by reddy View Post
    remove the rear seat, the circular cover that you'll find is the top cover of the pump. The FP of optra comes in set, meaning the fuel gauge is included in the assembly. Thunder sells the original at 12k.
    Nov 2011
    #38
    *larryswerte: Thanks for the info re denso fuel pump. I think it really did help a lot. However, you mentioned you fabricated the fuel pump. Just want to know if I did the right thing. I just bought a Denso Fuel Pump (just the FP motor without the assembly). Since the filter of the Denso FP is larger than the original optra's FP, is it ok just to fit it in without any modification on the yellow cylinder case of the original FP? Yesterday when I replaced it, the car did great. However, earlier when I drove to Lipa City, I feel the car was jerking a lot especially on the lower gears. When i parked the car, the engine sounded like the idling is too low even if the RPM monitor is steady at 9,000.
    If I replace the original FP motor, is it necessary for me to replace the original Fuel Filter? if not, what would happen?
    Again, thank you thank you very much!
    - Jon
    Jun 2011
    #39
    we have parts of optra and we specialized in it.
    general overhaul;
    top overhaul
    dukot
    timing belt,
    check engine etc...
    try us.
    orig parts and replacement..
    09164709860
    09212474805
    5441714
    Oct 2008
    #40
    bossing, saan ba ang store mo?
Chevy Optra: Fuel Pump Replacement?
