Page 25 of 25 FirstFirst ... 152122232425
Results 481 to 492 of 492
    Aug 2004
    #481
    Quote Originally Posted by jamesSB View Post
    bro,
    Available pa ba yung item. Thanks!
    Yes, available pa.
    #482
    Quote Originally Posted by viraccat View Post
    I owned a 2004 Optra 1.6L which i bought brand new from the casa in 2004. The chevy dealers have a promo up to Dec 31, 2010 for replacing the timing belt and tensioner for only P5.500+. My question is, would you have it changed considering that it has only runned for 30200km?. PLEASE ADVISE, Tsikoteers. thanks
    they might not change its timing belt/set.
    its timing set is set to be replaced every 60,000kms
    #483
    Guys ask ko lang kung ok lang gumamit ng Universal Lights para sa headlights ng Optra, Kasi ung low beam ng Optra about 1K pesos na ang isa sa Casa nung nagpalit ako last year. Ask ko na rin kung ok lang din yung sa break lights palitan ng Universal light. If ever, ano kayang brand ang ok? Thanks.
    Sep 2010
    #484
    I use Bosch Super Bright H7 (3200K at 88w). 750 pesos lang for the set at Ace Hardware. The first set I had lasted for 2 years.
    Quote Originally Posted by aldwyn View Post
    #485
    Philips X-Treme Power bulbs last set of bulbs na nagamit ko sa Optra. Sobrang lakas. Ganda ng output. No wiring modifications. Stock wattage 55W.
    1,500 bili ko sa Gold Cars Banawe..
    Sep 2010
    #486
    I'm interested in getting fog lamps installed on my 2006 Optra (base model). Any ideas how much this would cost to get done in the casa or another place outside?
    #487
    Quote Originally Posted by gearspeed View Post
    Optra the only car that the stereo is still running without the key...hehehe.Isa na yan sa mga defects ng Optra namin...
    The Blaupunkt Manual says the Optra is equipped with a radio which can be switched on even without the key. The radio will run for 1hour and switch off after that to save on battery power.
    Is this feature seen as a defect be some people? I find this a good feature on my Optra. I can leave people in the car whilst bringing the car keys with me and they at least have something to listen to.
    Jun 2011
    #488
    Quote Originally Posted by joseph_abri View Post
    how do i check the source of my car's overheat problem, its a chevy optra... here: the temperature rises up to almost 3/4 or even higher of the temp gauge... even with a bit short distances. it is gulping water every trip. it just happened a couple of days ago, both fans (auxiliary and radiator) working, replaced the auxiliary fan lately, and the thermostat... there is extreme steam pressure in the upper radiator, its hotter than the other hose, based from my touch, (this is where the thermostat is located), a day ago, there was steam coming out of the radiator reserve cap, replaced the cap now its ok, when i replaced the aux fan yesterday i removed and returned the upper rad hose connecting to the radiator, and clamped it, perhaps the clamp is not sealed enough as of today i can feel the steam pressure escaping from the hose that is connected to the radiator, might come back to the mechanic who put them yesteday to tighten the clamp... but i am not sure if that solves it, because there is still the overheat problem to think of,. how do i solve it...
    the rad months ago was replaced along with the aux fan and thermostat not more than 3 months ago, with chevy service center, if it continues heating the engine it might destroy the engine so i wanna pinpoint the problem.. and diagnose it correctly, i dont like the idea of replacing everything, just to make it work... if one can diagnose where is the source, well be answering the problem right on..
    test engine oil leak? test coolant leak? test rough idling? test engine performance? any engine noise? ticking sound? taktaktak?
    #489
    Well, if your car has been running fine prior to this problem, then there is a high probability that the trouble is within the cooling system only.
    [SIZE=4][SIZE=4]General Description [/SIZE][/SIZE]
    The cooling system maintains the engine temperature at an efficient level during all engine operating conditions. When the engine is cold, the cooling system cools the engine slowly or not at all. This slow cooling of the engine allows the engine to warm up quickly.
    The cooling system includes a radiator and recovery subsystem, cooling fans, a thermostat and housing, a coolant pump, and a coolant pump drive belt. The timing belt drives the coolant pump.
    All components must function properly in order for the cooling system to operate. The coolant pump draws the coolant from the radiator. The coolant then circulates through water jackets in the engine block, the intake manifold, and the cylinder head. When the coolant reaches the operating temperature of the thermostat, the thermostat opens. The coolant then goes back to the radiator where it cools.
    This system directs some coolant through the hoses to the heater core. This provides for heating and defrosting. The surge tank is connected to the radiator to recover the coolant displaced by expansion from the high temperatures. The surge tank maintains the correct coolant level.
    The cooling system for this vehicle has no radiator cap or filler neck. The coolant is added to the cooling system through the surge tank.
    Steam means boiling water, low pressure, and air in the system. The cooling system of the Optra is a pressurized system. For the Optra, you will see two hoses that go the the surge tank, one for the expansion of the coolant and the other for the return of the coolant. These are controlled by valves.
    Surge Tank
    Open Pressure of The Pressure Valve
    kPa(psi)
    117.7~147.1(17.07~21.34)
    Open Pressure of The Vacuum Valve
    kPa(psi)
    9.8(1.42)
    If there is failure here, the cooling system will not function correctly.
    If the pressure valve opens too early (at a lower pressure) the coolant will boil over. Hence the steam.
    Jun 2011
    #490
    for all owners of
    CHEVY OPTRA LS 1.6 DOHC E-TECH 2
    we do complete overhaul and top overhaul.
    we have our own optra ls 1.6 dohc.
    from piston, piston liner or sleeve, piston rings, engine valve,valve guide, valve seal,lapping, oil seal,head gasket, intake and exhaust gasket, pcv valve(the hardest to find). rear oil seal.
    and the crucial timing and the most hardest to determined for most mechanic outside casa,
    we already knew where to find these product, most of them are not available in thunder. even casa for PCV valve which is only 60,000 kms and need to be repalce.
    here some quotation:
    valve seal : 2450
    valve guide : 1350 sets
    engine valve : 650 each
    head gasket: 1350 orig
    camshaft oil seal: 280 each orig
    PCV valve: 1200 orig
    piston liner or sleeve : 1200 each plus 4000 labor for machine shop.
    Ignition coil: OEM php 3500
    labor:
    top overhaul (or dukot).
    php 4700
    plus machine shops labor:
    we can buy your parts or you.
    3 to 5 days depending on machine shop availability
    complete engine overhaul:
    from valve seal piston rings, camshaft, throttle body cleaning, all gasket replace and oil ring replace
    php 8500
    plus machine shop labor.
    5 to 8 days depend on machine shop availability.
    PCV VALVE valve last only for 60,000 kms.
    its only php1200.orig
    the chevy optra timing is crucial if the mechanic will do it for the first time is so confusing,
    and if he's not sure your engine valve get bend (550 each x 16pcs + machine shop labor +valve guide php1350)
    we allready encounter bend engine valve (optra) due to timing.
    php 25,000 all in all.
    we do home service for your optra.
    depends on how far from our shop in cainta.
    txt or call us:
    09164709860
    for parts 50% down and 50% upon delivery.
    tnx guys
    our first optra complete overhual
    from qc talyer pinasa samin
    from this........
    to this.....
    now.... another one.
    from chevy pasig c-5
    complete ovehaul
    busted oil pump.. 4,000 orig
    rear, front ,oil pump gasket.. need to be replace
    cylinder head gasket, oil sender, valve seal, piston ring.
    need to be replace...bearing....
    busted PCV VALVE , alot of additives , busted oil pump...
    will update when we put this back together... 07/08/2011
    Oct 2008
    #491
    bossing, saan ba shop ninyo?
    Jun 2011
    #492
    baka home service nalang kami muna mga boss... naghahahanap pa kami ulit ng pwesto tapos na contract sa last na pinagtayuan namin eh..
    txt nyo lang kami..
    09164709860
Chevrolet Optra [Merged]
