Results 621 to 630 of 1357
April 11th, 2014 02:58 PM #621
- Feb 2005
- 342
April 11th, 2014 11:35 PM #622good to know myth lang yun kung ganon. so, mas possibleng sira na yung shocks ng mga taong nag report ng ganon scenario dati?
I was referring to long periods on the lifter rather than a few minutes, like when they are working on the underchassis.
- Jun 2009
- 222
April 12th, 2014 01:17 PM #623I think its not a myth.
Shock absorbers (we call it dampers) can be damaged when loaded for long period while on fully extended stroke.
Shock absorber/damper is similar to a hydraulic ram/cylinders. The difference is, there is a tiny hole on the piston of a shock absorber/damper to allow flow of oil thus a regulated/calibrated movement of piston and rod is achieved. It effectively arrest the spring rebound so the vehicle is prevented from bouncing.
At fully extended stroke, all oil at the rod side of the piston is gone. Like a hydraulic cylinder, the shock absorber has a cushion (polyurethane) that could be crushed between the piston and the rod seal pack when all oil is gone.
When the cushion is crushed, there could be debris that could plug the tiny holes of the piston causing shock absorber lock-up.
The danger of crushing and breaking the cushion at fully extended is a wear/age issue because polyuretane becomes brittle over time. But sometime polyurethane cushion can be crushed or broken if some good mechanic simply used a sledge hammer to remove some axle parts while the axle is hanging unsupported on a lifter.
Another cause of damage at fully extended for long period is thermal expansion of oil (this happens in hydraulic cylinder). Oil expands when heated.
When the rod is already fully extend, the piston is on the top end. When the oil is heated due to increase in the sorrounding temperature it pushes the piston further causing damage of piston or seal or misaligment of piston and rod.
When driving or offroading, one or two wheels may hang. The shock may look fully extended but mostly it is not yet.
Shock absorbers, dampers and hydraulic cylinders are designed to have 2 to 3 speed of strokes. 3speed if has gas chamber. 2 speed if purely hydraulic. The piston actually has two sets of holes. A bigger (working hole) and smaller (impact prevention) hole. The bigger one will be covered by the polyurethane cushion near the top end leaving the smaller hole to allow small amount of oil to flow thus allowing the piston for a slow and smooth landing on the rod seal pack.
Sorry its technical...
- Apr 2014
- 3
April 12th, 2014 10:19 PM #624Hi guys. I'm a new guy and I need a little help. My father is planning to buy a SUV this moth but he is having a problem on choosing between the Fortuner and the Trailblazer. The new TBZ 2.8 4x2 A/T LT variant is our first option mainly because it holds the crown as the SUV of the year for 2 consecutive years. Secondly, it has a fascinating interior and exterior. However, we are concern about the fuel consumption of this SUV. And we haven't have any single idea about it. Can anyone up there help us and share their thoughts about this SUV, most specially to the owner of this said SUV. Ty
- Feb 2005
- 342
April 14th, 2014 03:04 AM #625
April 14th, 2014 12:45 PM #626
April 14th, 2014 03:00 PM #627
- Jun 2013
- 82
April 19th, 2014 09:11 PM #628Guys paano mag plastidip ng b-pillar ng tb? And ilang cans ito? TIA
Posted via Tsikot Mobile App
- Jan 2009
- 8
April 20th, 2014 07:13 AM #629
- Jun 2013
- 82
April 20th, 2014 07:33 AM #630
Xiaomi E-Car
