Page 3 of 52 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 1023
    #41
    sir the air horns you can get at any auto parts store.. that sells truck or bus parts too.. it cost bout P500 more or less.. the ARB compressor is from australia.. my dad got it for me.. i did most of the installations.. just had to get some hose fittings for the tank and hoses, .. the compressor comes with a pressure switch already. just search the net for anyone selling compressors here in manila.. they could be cheaper.. air tanks are not a problem. you can get them from junk shops.. or aircon shops.. you can have the freon tank converted to hold air.. kasi i think theres a law that prohibits freon tanks to be refilled with freon. so aircon shops should sell them cheap..
    you can also check the net for any DYI air horn systems..
    Mar 2011
    #42
    thanks! COOL! maingay ba kumakarga yung compressor? and gaano kalaki yung air tank? ppwede kaya yung mga 1 gallon tank or less? wala kasi akong space sa trunk.
    May 2011
    #43
    Am using Bosch Europa, though it's loud, those trucks and buses still seem to be deaf and still not hear it.
    Mar 2011
    #44
    Quote Originally Posted by cocoy View Post
    by the way, for got to ask, anong model ba yung arb compressor? eto pa yung portable? and automatic ba siya once full na ang tank?
    #45
    korsa gamit ko. mura lang saka ok naman. hehehe
    #46
    Quote Originally Posted by looks2008 View Post
    the model of the ARB compressor is the CKMA12, its the hard mount model.. the compressor comes with a pressure switch.. that turns off the compressor when it reaches 100 PSI.. and restarts when it goes down to 75PSI..depending on where you mount the compressor the noise varies.. it comes with rubberized bushings, which of course wears out. so the noise will become louder the longer you have it.. but ARB compressors are one of the best portable compressors available.. you can read bout it in the internet.
    Mar 2011
    #47
    thanks thanks! kaka research ko, napunta ako sa train horn. hahaha! interesting siya.
    Jul 2010
    #48
    aba, malakas yang train horn....yayanigin nyan mga sunog baga sa mga kalsada...nyahahaha..jk.
    #49
    hella supertones and fiamm air horns para sa mga makukulit na PUV and MC.
    Jul 2010
    #50
    sa akin pinalitan ko ng made in Italy horn pero neverheard yung name kaya di ko na matandaan yung marka...pero ok siya....
    have to go, good day Tsikoteers...
    God bless.
    #51
    have Seger horns on my starex.. along with a bus horn. with ARB CKMA12 air compressor.. that fills up 1 gallon tank located under the starex.. very loud talaga.. used to have stebel nautilus air horn.. just wasnt loud enough.. now buses and trucks think twice...
    nice setup!
    ive always wanted one of those. mahal kasi sa Hornblasters.com kaya ok pag DIY
    May 2011
    #52
    My Stebel Nautilus horn has gone flat on me only 3 months of use. It still works but mahina na sya. Bought it from a reputable shop along C3 in Caloocan aswell.... Hayyy
    What other horns are good?
    #53
    Quote Originally Posted by DeathRow View Post
    return to the shop and have them look at the connection, wiring, etc
    Ang aga namang bumigay niyan? Stebel pa naman gusto ko next bilhin.
    Hella Supertones na lang kaya. Matibay ba?
    #55
    Any recommendations para sa Jazz ko? It's just 1 month old, was asking honda to change the horn to an Accord Horn, pero di daw nila ginagawa yon. Recommendation lang nila is to have it changed sa labas na hindi na kailangan mag rewire at gumamit ng relay para di daw ma void warranty.
    I need a horn na malakas, buo yung boses sana or malalim, but it won't need any rewiring.
    Nasanay kase ako with mitsuba and Bosch Air horns, ngayon sobrang pipit boses nung horn ng jazz ko, di ko naman magamit yung bosch ko na air horn dahil kailangan mag relay.
    Maraming salamat po sa mga magrereply.
    #56
    Quote Originally Posted by imogen View Post
    fellow GE owner here! i know how you feel! ang hina ng stock horns ng jazz GE.
    I've had several upgrades with my horn. Here's the list in chronological order:
    1)Bosche ec6 - no need to rewire, louder tha the stock horn but i replaced them with
    2)Bosche Airmaster - very loud and high pitched! my fav until it gave up on me. needs rewiring. now, im using
    3)Hella Supertones (ST) - nice stock sounding horn but not as loud as i had expected. maybe because the ones i got are from india, not germany. my friend has one in her car but it sounds louder!! this horn needs rewiring
    im planning on getting Fiamm Gran Turismos (GT) next. I'll just place a switch for the GTs and the STs
    #57
    Quote Originally Posted by watusi View Post
    Alam ko madali talaga masira ang Nautilus lalo na kapag palagi binababad.
    Stebel TM80 Magnum tested na nung friend ko sa Tucson niya. Mas babad siya sa'kin bumusina pero oks pa. Yung Hella Twin Tone ko bumibigay na.
    Balak ko palitan ng Mitsuba Proud horn or Mitsuba Alpha II horn.
    Nice GE! Ganda ng color.
    Diba dual horn na rin ang stock ng GE? AFAIK pwede plug and play lang yung OEM Mitsuba horns ng Accord dyan. Same naman sila ng socket at voltage. Ganun pinagawa ko sa CR-V, P1,500 lang sa Honda SPA.
    Ah ok, thanks, will try to find one.
    #59
    Thanks sir! nakapag papalit narin ako ng horn sa honda SPA, pero na 2,300 pesos ako pati labor, high and low horns, mitsuba nga po sila for accord and bolt on lang, mas mataas lang ng .5 amperes each sa stock ng GE ko, wala raw yon problem sabi ni Sir Abet(Service advisor). Really good sound and malakas sya, tumatabi naman mga bus sa EDSA so far, hehehe!
    Oct 2008
    #60
    pano yung warranty? void daw ba or hindi? sa honda san pablo kasi void daw..
What is your car's horn?
