Results 1 to 20 of 20
    Hi. Tumawag ako sa Honda kasi gusto ko magpakabit ng alarm para sa brand new Honda City ko. Sabi nila 5,415 daw ang price para makabitan nila to. Titan daw yung brand ng alarm. OK ba ang brand na to? Di daw ako pwede magpakabit ng alarm sa iba kasi mavovoid daw warranty ko eh. Need help pls. Thanks in advance.
    Quote Originally Posted by hcdangan View Post
    sayang sir, sana yung binili niyo pa lang nakapagdeal na kayo sa SA, usually they will give you the alarm free if you get the insurance from them. anyway, same brand yun alarm ko and honda quezon ave nilagay. ok naman yung alarm up to now pero yung isa nasira ko na. hehehe
    btw, 8 years na lakakabit yung alarm ko. satisfied naman po.
    May 2005
    there's a lot more alarm brands na mura yet better tha titan. You could ask your dealer if they would void the warranty if you buy outside the alarm and Honda Casa mag-install. Logically, that shouldn't be a reason for voiding the warranty kasi sila din ang gagalaw sa electricals.
    Jun 2005
    Titan ang pinakabit ko sa Innova J ko last 2005. It's still working. Hindi ko lang masabi kung okay ito compared to other brands.
    :coffee: [SIZE="1"]3479[/SIZE]
    Nov 2007
    titan is ok naman...just be aware that titan alarm sometimes have a weak signal...you have to put the remote so close to your unit before disabling the system...since honda yun unit and if you got some extra money to spare I suggest you go with the Code alarm
    Quote Originally Posted by ans_lim168 View Post
    Are you referring to the Code Red alarm na nabibili sa Blade?
    I had a bad experience with my Titan Car Alarm that was factory installed by Honda Alabang. It just hang and I needed to bring the car back twice for the car alarm issue. They failed to repair it so they just changed it to another alarm....
    After they changed the alarm, I lost a couple of salient features of the old alarm, like valet mode and shock mode.... I did not complain anymore,- at least I have a 'working alarm' than no alarm at all....
    5606:jazzysax:
    Nov 2007
    Nope...this is the alarm system that is US made...honda car dealers sell these and Winterpine along Araneta ave. QC
    Wow. I guess I'll ask them if they have Code Red. Honda Cars Makati btw.
    sir i thnik your reffering to code alarm, not code red.
    anyway, honda has them pero double the price than the titan. if you can afford it then ok talaga yung code... matibay talaga.
    I called Honda and inquired about the Code alam that you mentioned. It costs 7,600 (less 10% na yun). Whatdapaakkk!!! They also have the AVT alarm that is at the same price as Titan. Which one would you recommend? OK din ba ang AVT?
    sir, the code alarm ok talaga... yung cousin ko nasama niya yung alarm sa swimming pool then blow dry lang and gumana ulit. hindi ko lang alam kung lucky lang or waterproof talaga.
    for the titan and AVT.. havent heard of AVT, pero yung titan ok naman... draw back lang is habang tumatagal kailangan mo lumapit sa car mo for it to recieve the signal.
    overall ok naman talaga sakin yung titan. i dont have to be far naman to turn on the alarm.
    Quote Originally Posted by archie123456789 View Post
    Maybe the range is caused by the battery being drained as you use it? Natry mo magpalit ng battery sa remote? Ang mahal kasi ng Code eh waaaah
    As long as it served the purpose and works fine, I think you don't need to have costly alarm system...practical ka dapat. Kahit mamahaling alarm pa naka kabit dyan kung intentionally e vandalize yung car mo walang magawa ang alarm dyan. So, as long as it works fine and doesn't easily get damaged...its the practical choice.
    Jan 2008
    I have both Titan and Code alarms installed in different vehicles. One of the Titan alarm's remote controllers malfunctioned during the first year (not a battery issue). I brought it numerous times to Honda and they fixed it but then it is broken again. The only solution now is to buy a replacement remote controller (P700 I think) but that is not the same shape and size as the original I got. BTW, the alarm is almost 4 years old.
    As for the Code alarm, I think it varies on the model. I have a friend whose Code alarm works from over a hundred feet away while that I have is no good beyond 30 feet. I had this checked many times but Winterpine said they can't do anything more. Also, the siren unit is small (others have larger units that make a whole lot of noise - good deterrent). This Code alarm is less than 3 months old and it has not met my expectations completely.
    As for AVT, I have no experience with this brand except for the HU of my Grand Starex (and we're talking alarms here). So I'd go for Code first (though it's more expensive) and Titan next.
    sir actually kahit anong palit ko sa battery ganon pa din.. well lalayo yung range ng about 10 feet kung bago battery pero little improvement lang. i get it to arm and disarm mga 5 feet normally. mahal talaga yung code alarm, lalo na if you get it from honda.
    sa totoo lang, it dosent bother me about the range basta magarm lang yung alarm ok na ko... its just a plus if the range if like a 100 feet.
    im just waiting for it to break (kung masira pa) para i could get the code with auto start.
    Quote Originally Posted by txtalert View Post
    I suggest u go for GSM car alarm like what we have been doing. Wala kang problem sa distance kasi GSM. We also incorporate it with a GPS so u can also track your unit using a free map software like Google Earth. Immobilize it remotely as well as lock/unlock the door, no problem. Your cellphone will be its controller or any cellphone will do provided u will let them know your password and the cell no of the unit installed in your car. Very effective and satisfied ka talaga sa performance. The best anti-carnapping and anti-carjacking talaga.
    GSM alarm is not available at Honda. I can't use other alarms because Honda will void my warranty if I have my car serviced outside casa.
    With regard to the auto start feature, I don't think my City can have that because it has an immobilizer. The original key must be inserted to start the engine.
    Maybe I'll try the Code alarm. Does anyone have a picture of the remotes of the Code, AVT, and Titan alarm? Google gives me too many results that confuses me.
    I found this image from google, but I don't know which one Honda sells:
    http://kcautosound.net/promos/12_12_code-add.jpg
    sir yung sa casa, all black yung code alarm remote.
    Jan 2008
    Here's the website of Code Alarms : http://webappshttp.voxdmz.audiovox.c...vlet/index.jsp or
    www.code-alarm.com
    Most models sold here are the low end models (if these are the ones under P10,000, these are usually CA100, CA110, CA120, and the like). I'd suggest the CA130 or CA150, depending on the budget. If the Honda City has built in keyless entry but no alarm, then get the CA310. Most of the new high end models available for 2008 would not yet be stocked in majority of the car accessories stores.
    Thanks for all the inputs. I'll go see what Honda has.
Okay ba ang Titan Car Alarm
