Page 11 of 48 FirstFirst ... 78910111213141521 ... LastLast
Results 201 to 220 of 951
    #201
    Get the basic Code Alarm system. Model CA-100. P4,000 at Winterpine.
    Has all the basics...active / passive arming with door locking both user-selectable, on-the-fly passive arming in silent places, plus an anti-carjacking feature ala Lo-Jack.
    Aug 2006
    #202
    Update ko lang sirs. I bought the Autopage RF-315 yesterday. Tiwala naman ako sa nag-install since he's the same guy who installed my Krypton alarm three years ago. After some haggling, the shop sold me the car alarm at P3,800 (with free installation).
    So far, okay naman siya (para lang yung old Krypton jo but with smaller and thinnier remote). But the installer did not activate the ignition kill feature, saying such is not advisable for automatic transmissions like my car.
    I'll keep you updated kung may mapansin akong problem. Thanks!
    #203
    Parang wala namang kinalaman sa transmission yung iginition kill. It's just a relay that does not allow electricity to flow to the starter or fuel pump. Yung Picanto a/t pinalagyan ko nun. Same procedure din as dun sa pagkabit sa Vitara m/t kahit magkaiba pa brand ng alarm (Police vs. Venom).
    Aug 2006
    #204
    I'm also still wondering about that... Yung explanation kasi nung installer medyo technical for someone like me na bago pa lang humawak ng A/T. And since nagmamadali ako that time, I decided to just let him activate Autopage's basic features.
    One of this days I'll try to confirm this with other installers. By the way sir, if you could also help me about this, I would appreciate it. So far I'm content with my new car alarm. Thanks again.
    #205
    I do not want to speculate about your installer. But the reason some shops do not install the iginition kill is so they can keep the relay and relay socket to themselves (para mabenta or magamit sa ibang projects).
    Dun sa nagkabit ng alarm ko 'by request' ang ignition kill. Free kung irequest mo. Kung hindi, hindi din ibibigay yung relay at socket sa iyo.
    Aug 2006
    #206
    I think you're right. Wala siyang binalik na relay or socket sa akin. I may vouch for the installer's ability but I certainly could not ascertain his honesty and fairness towards his customers. Anyway, charge to experience na lang. Next time di na ako masyado mauutakan. Thanks.
    May 2005
    #207
    meron akong autopage pero di ko alam ang model. yung isang remote, di naka-program para sa controller.
    pwede kayang i-reprogram pa ito para magkaroon ako ng spare na remote?
    TIA
    Nov 2006
    #208
    Mga sirs, among the three shops sino po dito ang mas reliable/mas expert magkabit ng alarm based on your own experience: Winterpine, Goldrich, or sa Araneta Car Accessories??? Mas ok po ba ang Autopage alarm vs. Viper/Cobra/Alien??? T H A N K S.
    #209
    Ibang level na ang Autopage at Viper. If you can afford them, go for it.
    But the Taiwan alarms, Police/Venom/Cobra/Predator works well enough.
    Sa ACE ko pa lang na-try. Binantayan ko every step of the way. Tama naman lahat ng ginawa.
    Yun nga lang, you have to request for ignition kill (free of charge naman ito). If not, they will not install the ignition kill.
    Sep 2006
    #210
    mga ser meron ba may alam how much yung stock na alarm ng ford lynx 03?
    #211
    Otep,
    Just to clarify, is the "ignition kill" feature the one preventing anyone from starting the car while the alarm is armed? So the effect is when you turn the switch, nothing happens, as if the battery is dead?
    #212
    may remedyo pa ba ang alarm na nalubog sa baha? damuhong "milenyo" yan umabot hanggang upuan ng revo ang baha... noong una umiingaw pa ang alarm (stock ng toyota) tapos hanggang sa nawala na. nilinis ko na ang board pero ayaw pa rin gumana. ang hirap din rumekta sa toyota kase bibentahan ka lang ng bago. tnx
    #213
    Otep,
    That depends. On the MB100, the engine will crank but it will not start. On the Picanto and Vitara, there is no crank at all.
    In both situations, the alarm will also trigger.
    #214
    Ah I see. Well, either way you still won't get to start the car.
    I haven't actually on purpose tried stress-testing that feature before (by opening the door with the key and trying to start the engine while the alarm sounded). But there was one time I panicked for a second. That was when I was seated on the passenger's side and I locked myself in, arming the alarm in the process, while I was reading something. Then when I felt warm, I proceeded to start the engine. Ayaw! Wala man lang redondo. Parang patay na yung battery. Well, siguro lang naman. Naka-arm nga pala yung alarm.
    So this was proof that the ignition kill switch was working while the alarm was armed. (This was also proof ng katalinuhan ko. Wahaha! )
    #215
    I would prefer that the ignition cut off be put on the fuel pump instead of the starter. That's how they did it on the W123 Mercedes on its first alarm system (back in '96, I think). That way it will also work as an anti-carjacking feature.
    What happened was the driver accidentally hit the arm button while we were in traffic. After a few seconds, the engine died and the alarm triggered.
    But if the technician doing the install does not know how to install that way, ayoko na pilitin.
    #216
    Pwede nga naman, but then most car remotes nowadays are useless once the key is in and turned to accessories. Or is that just the way Toyota wired their alarms?
    #217
    sir otep does this work for diesel cars too? and by the way where is winterpine located? thanks in advance...
    #218
    Sir, diesel po yung W123 namin (300D siya).
    Sa Jaffas Banawe po kinabit yung system na iyon. Jaffas is Banawe near corner Mayon.
    Winterpine is along Banawe. Near Nacional and Arlington but on the opposite side.
    #219
    sir otep, so the autopage 315, version can be conected this way?i just read the threads,, what would you recomend for an alarm under P5000? i guess i want one that would be effective.... thanks again....
    #220
    nagpakabit ako ng RED X alarm kanina kila jeff tan..1 year warranty rin, taiwan made also like venom and police..wala daw kasi stock ang venom..got it for P2,200
car alarm: anong maganda ngayon?
