Page 3 of 176 FirstFirst 12345671353103 ... LastLast
Results 41 to 60 of 3510
    Jan 2009
    #41
    Here's a sample of an actual recorded clip from several nights ago. Please note that the artifacts wasn't there in the original video. It somehow got into the video either during the conversion in Movie Maker or while publishing it on YouTube.
    [ame=http://www.youtube.com/watch?v=6YGpuKaMGvE]X3000 Car DVR/Blackbox - YouTube[/ame]
    Jul 2005
    #42
    I'm considering getting the rear view mirror type para di masyadong nakaka-distract. Any reviews?
    OJ88,
    Thanks! Ganda pala kuha.
    Jul 2005
    #43
    I just ordered 2 units - one is the same as thread starter's unit and the other is like this:
    I'm going to keep one a sell the other. Iniisip ko pa ngayon saan sa dalawa gagamitin ko. I'm more inclined toward the rear view mirror type para di masyadong cluttered windshield ko and pwede pihitin ang camera if needed like when I'm being apprehended by a kotong cop. Kaso wala itong GPS and shock sensor. Hmmmm... ano sa tingin nyo? Hirap mag-decide.
    Jul 2005
    #44
    Quote Originally Posted by garci View Post
    Hehe. Naku hirap mag-decide nyan. But whatever you decide on, i will be interested with the one you'll sell. Pa-PM na lang sir pag benta mo na yong isa. Thanks!
    Jul 2005
    #45
    Decided to retain the X3000 not because it performs better than the rear view mirror. May pros and cons pareho.
    Anyway, GPS ba talaga ang source ng battery drain? Di ba nagcha-charge yung sa inyo while driving? I'm having battery drain issue din and it's causing the last footage taken to get damaged pag pinatay ko ang makina na drained ang battery.
    May 2011
    #46
    curious din ako dito, gusto ko din yung idea na nagrerecord siya habang naka-park ako para malaman ko kung ano nangyayari sa sasakyan habang wala ako.
    #47
    ^That would require a lot of memory space. So far 32GB ang pinakamataas na nakita ko na micro SDHC. And yung battery life nya di maglalast for the whole day IMO. Delikado rin pag sa arawan ka nagpark kasi naiinitan talaga sya plus it's running so additional heat pa, baka masunog. Kung saglit lang say 30 mins to an hour pwede pa. Pero kung whole day, medyo di na practical. An hour of driving kasi, nakalagay sa file size around 4500MB+, just imagine kung whole day.
    May 2011
    #48
    ah, i see. perhaps there's a product like this that has a sensor? when the sensors engage, it shoots for a certain amount of time?
    May 2011
    #49
    *oj, meron bang option to disable the recording of the the rear cam?
    iwas pusoy ke mrs. hahaha!
    currently using cdrking DVR-017 (1.8k), not quiet happy with video at night...
    Jan 2010
    #50
    I'm tempted to get this kasi HD na raw:
    http://www.**************/index.php/...OS+Sensor+HDMI
    Jan 2009
    #51
    Quote Originally Posted by skybison View Post
    Yes. Nasa menu if you want to record just Ch1 (front), Ch2 (rear) or both. You can also disable the audio/mic recording.
    Manyak mode. :D
    Jul 2005
    #52
    Manyak mode. :D
    Opened up the GPS antenna.
    it's not just an antenna but whole GPS module na pala.
    Oj88,
    Nagawa mo na ng paraan yung GPS battery issue? Yung akin kasi di ko na lang kinabit. I'm thinking of installing a switch to cut off the power when not in use or better yet a 5v normally open relay para automatic.
    Jan 2009
    #53
    Yup. It's an active GPS receiver. It needs 5V power from the DVR and it sends back GPS coordinates using serial communications (ie. NMEA 0183 protocol). The memory backup battery is a dead giveaway. The memory serves to store ephemeris data and whatnot.
    Oj88,
    No I haven't tinkered with it. Like you, I also temporarily disconnected the GPS module.
    I've thought of using a relay as well, one which can be triggered by the DVR's backlight circuitry or the power LED. The thing is, I'm not sure if the 3.7V LiIon/LiPoly battery will be enough to energize the 5V relay. In that regard, I think that a solid state approach is preferred (smaller package and lower power draw). I just haven't found the time to design the circuit yet.
    But do tell if you make any developments.
    Jul 2005
    #54
    My idea is simply to cut off a power wire from the DVR to the GPS module, connect it to a 5v triggered normally open relay and connect the relay power terminal to the 5v supply of the DVR (or a separate 5v USB car charger). so only whenever I the engine is running magkakaroon ng contact ang relay to supply power to the GPS.
    Problem lang is I don't have a relay and ayaw kong pumunta ng Raon just to buy one.
    #55
    Ako dinidisconnect ko yung connector ng GPS everytime I park. Kaya namang sungkitin ng daliri ko hehe. Mas hassle kasi pag naubusan ng batt yung DVR, narereset yung time and date. Set up na naman kada bukas ng DVR.
    Jan 2009
    #56
    I want the most elegant solution kasi. Call me maarte.. :D
    I'd want the GPS module to power up and down with the DVR, not the ignition key. So I can still move it temporarily to another car with the GPS module intact and fully functional, running off the DVR battery. Kaya it's taking me a while to think it through.
    #57
    ^I feel you hehe. Kaso ako medyo mahina sa DIY lalo sa electronics.
    Jan 2010
    #58
    Are there other alternatives other than the ones posted here and CD-R King?
    #59
    i also bought one here in Taiwan.
    Full HD na. a bit more expensive than the x3000
    sample video from youtube.
    #60
    CB , ang linaw ng kuha kahit gabi. magkano yung ganito
Blackbox DVR/Dashcam
