Results 1 to 10 of 13
- Mar 2007
- 425
July 30th, 2014 02:24 PM #1I thought this is more of an electronics issue.
I'm driving my Ford Escape, and several times I noticed tool late that I had the handbrakes engaged while I'm driving. There are times I didn't notice the handbrake lamp. My bad.
Has anyone ever installed a device to send out an alarm when the handbrakes are engaged and the car is moving already? The alarm shouldn't be scaring, just gentle enough to remind the driver that the brakes are still on.
- Jul 2011
- 1,711
July 30th, 2014 02:43 PM #2gawan mo ng relay, tapos micro switch sa gas pedal, at sa dulo buzzer.
pag naka ilaw ung handbrake lights, ung relay mo naka power din, so mag close position.
ung isang paa naka series sa micro switch, normally open, pero pag tinapakan mo ung gas pedal ma triger ung switch at mag close ito, then ung wire ikabit mo sa buzzer.
tutunog ang buzzer pag naka handbrake ka at tumapak ka ng gas pedal, regardless if moving ka or not.
- Mar 2007
- 425
July 30th, 2014 05:44 PM #3Hi Manilablock,
Salamat sa suggestion mo. Pinag-iisipan ko yan noong dati pa. In your version, pag-nagrev ka lang, buzzer agad. Hassle. Yung microswitch dapat nasa gearbox. Sa MT, off ito pag nasa neutral, anywhere else, "warning: brakes still engaged"
For matics, in my case, naka-wired ito sa mga indicator lamps sa dashboard. Isip-isip...
Baka may gizmo na nagtitinda na ito?
- Jul 2011
- 1,711
July 30th, 2014 06:26 PM #4pag nag rev ng naka handbrake, meron buzzer. mahirap naman na kung aandar saka lang mag buzzer, baka meron ng masira.
pero pag naka P or N at hindi ka nag handbrake pwede ka mag rev.
yan lan ang naisip ko na mura lan at pasok sa gusto mo.Last edited by Manilablock; July 30th, 2014 at 06:28 PM.
- Mar 2007
- 425
July 31st, 2014 09:23 AM #5At lakas ng loob. Splicing and tapping wires inside the dash.
Salamat, and enjoy!
July 31st, 2014 10:08 AM #6
teka lang, anong sasakyan ba gagawan mo niyan? meron na ganyan features mga sasakyan ah...
July 31st, 2014 11:16 AM #7
Meron ganyan feature ang sasakyan namin. Kapag nakahandbrake tapos umandar ka (around 15km/h) may alarm na tumutunog to warn you.
- Oct 2013
- 2,537
July 31st, 2014 02:14 PM #8kung ako sayo TS, always make it a habit to glance at your instrument panel, basic rule says never drive with anything red on the panel...
- Mar 2007
- 425
July 31st, 2014 02:23 PM #9Shadow,
Sa Ford Escape sana ko ilagay. Even with the brakes engaged, di mo ramdam na mabagal. Mapansin ko na lang sa dash pag tigan ang speed ko. In my other ride, Zuki APV, pag sobrang bagal, alam ko na naka-handbrake ako.
Not all cars had this warning feature. Extra vigilance required.
- 3,754
July 31st, 2014 07:20 PM #10We did it before sa old honda accord limit switch lang nilagay ko pag nasa D mag alarm sya then to reset another limit switch connected to hand break lever pag naka lower na yung hand break ma cancel na yung alarm.
Xiaomi E-Car
