Results 1 to 5 of 5
November 1st, 2014 01:22 PM #1
Diba yung ibang sasakyan pag nag reverse(atras) may sound. Pansin ko lang sa trooper namin pag nag reverse ako yung sounds nya bumibilis hindi katulad dati na kalmado lang ang sounds.
November 2nd, 2014 06:25 AM #5
Verify that it is indeed from the reverse sensor.
First, check if there is dirt/debris on the recerse sensors. If not, check the orientation of the sensors. Usually, the sensor are required to be oriented a certain way. Try to look att each of the sensors. If you see a protruding dot on it, the sensor should be oriented in a way that the dot is perfectly at the bottom or nearest the ground. If you don't see a dot, there should be an indication at the back of the sensor about which way should be up or down, or the body of the sensor may be 'keyed' to only enter the bumper a certain way.
Was the rear bumper damaged, removed, painted, or serviced in any way?
Xiaomi E-Car
