Page 6 of 6 FirstFirst ... 23456
Results 101 to 116 of 116
    Feb 2011
    #101
    Quote Originally Posted by venerzky View Post
    Any Garmin Nuvi 55LM or 65KLM users here?
    anyone who sells brand new or 2nd hand garmin units for a reasonable price please message me. thanks.
    Jun 2015
    #102
    Can you charge a garmin unit using a power bank?
    #103
    Quote Originally Posted by G++ View Post
    Yes sir. As long as 5V and at least 2000mAh ung powerbank output, and you have the correct connector[emoji1].
    Edit: I can charge mine sa USB port ng laptop so 100mA charger might work.
    Sent from my D6503 using Tapatalk
    Jun 2015
    #104
    Sir yung stock cable ba hindi pwedeng gamitin? I'm planning to buy the Nuvi 57 sana.
    #105
    Depende sa connectors sir. Most powerbanks have micro USB cables while most (if not all) Garmins have mini USB charging ports. I have both the nuvi 960 an nuvi 2565, pareho silang mini USB. Ewan ko lang sa latest models sir. Kung pasok naman yung connectors ng powerbank mo sir, pwede dapat yan
    Jan 2011
    #106
    Quote Originally Posted by jettp0gi View Post
    You can charge a Garmin with a powerbank using stock cable. However, using the stock cable will make the Garmin go into PC connection mode. It won't do if you're planning on using the Garmin for navigation while connected in this way.
    One of the pins in the oem Garmin car charger mini usb connector is wired differently so it doesn't go into pc connection mode. You can search for it with Google. You'll have to modify your usb cable in the same way if you plan on navigating while connected to a powerbank.
    #107
    Quote Originally Posted by cityfolk View Post
    Most units sir, will ask you if you want to go PC mode or navi mode upon plugging in sa micro USB. Mine does.
    Apr 2010
    #108
    mga bossing, pwede pa po ba magamit ung nuvi 1300 dito sa pinas? sabi kasi sa garmin dealer sa subic obsolete na daw ung model at di na daw pwede madownloadan ng phil map? sayang naman kasi kung di magamit, galing US po sya. help naman po kung pano magdownload ng map kung pwede pa magamit, salamat.
    Jan 2011
    #109
    It's good that Garmin changed the behaviour with the newer units with micro usb port. I have two older units with a mini usb port and they do not give you a choice.
    #110
    Quote Originally Posted by raycor View Post
    Pwede pa yan sir. Yung isang nuvi ko is 960 (which seems older than yours), nagana pa naman sya. Depende siguro sa map na tinutukoy nya yun. Marami din naman maps dyan like openstreetmap or roadguide. Need lang maging contributor sa roadguide to gain access to the comprehensive map.
    #111
    It should work here in our country with the right local map.
    If it has an SD slot then, it should be better. You just copy the map in the SD card.
    29.8K _/_/_/_/_/_/_/_/_/_/
    Jan 2013
    #112
    Some proprietary maps are unit-specific though. Meaning it will only work on a specific unit with specific serial number and can not be copy-pasted to another unit even if they are the exact model. I am referring to roadguide's map. There is an alternative, search for OSM-PH map. That one is a legally free downloadable map. Roadguide is free also but in order to get the latest map, you need to have a contributors status first.
    Quote Originally Posted by remzam View Post
    Thanks for the tip. Will give this a try.
    I installed the one from osm-ph 9n my navi lm65 and it worked great! Thanks a lot *remzam! Owe you one.
    #115
    Sino may latest version ng garmin maps for the philippines? baka pwede pahingi ng link.
    Signature
    Openstreetmap.org.ph/garmin. You need to download the mapsource installer and connect your garmin.
Review for Garmins GPS w/ Philippine Maps
