Results 11 to 16 of 16
- Sep 2006
- 19
September 27th, 2006 03:18 AM #11i know someone here at landargon, araneta, quezon city, malapit sa shell, na magaling mag timing.. without the aid of the timing light.. he is just like, rotating the whole distributor and his only basis is the sound of the engine.. pakiramdaman kung baga.. share ko lang po.. now i know the timing light is used for reading and the mechanic will still be the one who will make futher adjustments! i really have to have my car timed properly.. lakas ng gas consumption! hay... pansin ko lng po, mei mga degrees, like 5, 10, 15 deg. ano ano po ba ang characteristics ng bawat degrees when on them? which is Most efficient, maayos na hatak, ngunit nde ganun ka-takaw sa gas? my engine is 4g32 1.6L
thanks!
cheers!
- Sep 2006
- 19
September 27th, 2006 03:19 AM #12pahabol ko lang po, ano po ang mga possible problems na mkukuha sa patuloy paring pag paandar ng poorly timed engine?
thanks!!!
September 27th, 2006 11:45 AM #13
same question din po.
ako worry ko kung ang timing belt wala sa timing or wala sa centro ano possible cause. right now im encountering low power on 1st and 2nd gear naiiwan ako sa stoplight. any recommend shop na magaling magtono? sabay ko na din change oil ko. thanks
Toyota is my choice
- Aug 2005
- 2,063
September 27th, 2006 12:34 PM #14
September 27th, 2006 04:03 PM #15
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 27th, 2006 10:38 PM #16different cars need different degrees of timing. don't have it adjusted kung walang timing light or kung hindi masabi sayo ng mechanic mo kung ilan yung dapat na nakalagay.
Traffic!
