Bougt Philips XV for P1500 at catronics...
sorry for dumb question...one pair lang ba ang kelangan ireplace or bilhin kpag maguupgrade from stock to philips xv? will the pair of bulbs already cover the high and low beam? thanks!
H7 philips extreme vision bili ko noon sa blade 2400 over 2yrs ago.
just this week napundi na yung isa I replaced with the same extreme vision uli 1800 sa roadstar alabang.
HTH
mga paps, nakabit na yung philips xv sa honda jazz ko kanina... 1500 sa cartronics... then nung pauwi na ko ngayon lang gabi, pansin ko parang may mali... parang mas nahirapan yung visibility ko sa night drive vs the stock halogens... to the point na muntik na kong bumangga jeep naka stop pla, as in di ko sya nakita nung malayo, nung malipit na lang sya biglang narealize na jeep pla sya...never ko tong naexperience to sa stock...
naisip ko baka may mali sa installation...does this happen? may kelangan pa bang i-adjust...is there something to do with the cutoff? parang di ganun ka sharp or definite yung cutoff or line nung ilaw...tska parang ang baba nung buga...kse napansin ko dina di ko kaagad mabasa yung plate number nung katapat kong kotse unless tutok ko na sya...theses are my observations at low beam. i was supposed to capture everything in video pero na low bat na cel ko...
naobserve din oaka to ng passenger ko, sabi nya parang di kaagad makita yung kotse sa malayo, mga 3 to 4 cars away parang shadow/silouhette pa din...
then kapag hi beam nman, maliwanag naman sya, malakas yung buga..to the point na nakakasilaw yung light reflection sa kotse sa harapan ko...yun lang sa low beam lang parang may mali...
then while driving at night, biglang bumuhos yung malakas na ulan...wala na, as in kelangan ko nang magslow down almost to a near stop kse puro liwag lang yung nakikita ko na maputi...
this is just very weird considering clear tints na ko...
haay...pano kaya to?
tinanggal ko muna yung philips xv and returned the stock bulbs... will make a test na lng mmyang gabi so I can see the difference... sana nga sa seat positioning yung cause...
i was thinking was its because of the white color of the light kaya di masyadong prominent yung line or cut off???
tska wla naman tong particular na left or right bulb db? any which way nman to right? correct me if i am wrong...thanks!
will try to take some photos later na din...
both bulbs ( right/left ) is the same. cut-off as well as the height should not change.
paps, yellow street lights along ortigas ext going to medical city and tiendesitas... i even tried turning the headlights on and off whiile driving kse nga parang visibility... hehe...
di nga kaya dahil color blind ako? hehe... anyway nabili ko na yung bulbs eh... might have to stick with it for the meantime and adjust...
now thinking of all weather bulbs... what would you suggest kaya? or probably retrofit by garyq P18k?! kaching kaching!
kaya i still prefer the XPs over the newer XVs. one neighbor also commented on the yellow street lights cancelling out his white XVs on his car...
DIY pwede na, no need to bring it to the casa.
i saw the photo below on the Internet. hope this helps
the photo is from a GD model but the GE's is basically the same
photo from http://www.fitfreak.net/forums/fit-i...ts-must-6.html
paps, magkaiba yung adjustment ng GD and GE... good thing may nakita akong pic sa net, eto yung daw yung headlight adjustmentbolt for GE...
backview photo of the headlight assembly
honda jazz GE headlight adjustment bolt:
will tinker with it kung clockwise ba or counter...
