Page 22 of 36 FirstFirst ... 1218192021222324252632 ... LastLast
Results 421 to 440 of 717
    #421
    Quote Originally Posted by beni23 View Post
    Ano naman kaya magiging difference if I replace my stock foglight bulbs with this h11 osram NB+?
    Sent from my iPad using Forum Runner
    Based on users of Osram NBP like Sir crazy_boy:
    "crazy_boy
    chiks, i replaced my stock halogens to ONBP, laki ng difference talaga compared to stock. minsan hindi na ako gumagamit ng front fog lights."
    It is brighter than stock bulbs and 10% whiter too. There is still a little yellow color so that the light won't reflect on the road when raining.
    #422
    Quote Originally Posted by xtian09 View Post
    "crazy_boy
    but iba ang throw ng ilaw ng fog lights. Yung karamihan kasi dito is for headlight yung comment just like mine.
    #423
    Fogs are low and wide, vs headlights which should be higher and should throw light farther. They really do complement each other as the fogs help to enhance the shorter distance by making the beam thicker (fog beam + headlight beam).
    With a good set of foglights and driving in city traffic, sometimes you don't need headlights. The rub with overpowering/overachieving fogs on the other hand is that they can mess up your distance vision since the nearer beam is thicker and it takes a while to adjust your eyes to look farther -- where the fog's beam does not reach.
    #424
    +++++++++1
    #425
    *xtian09 - Sir do you have an available H27/880 type of bulb? Thanks!
    #426
    Quote Originally Posted by mateomarco View Post
    None sir. Konti lang kasi kumukuha ng ganyang fitment.
    But for sure, many online sellers out there has that kind of bulb.
    Usually H.I.D. online sellers has this kind of fitment.
    I will try to look for you if you really want halogen bulbs.
    Mar 2011
    #427
    sir xtian
    advice po jazz GE po
    planning to replace the stock headligth bulb?
    Parañaque - Shopwise Sucat
    tnx
    godbless
    #428
    Okay sir...Thank you for your assistance...please let me know if you have one available na...i prefer all-weather/yellowish halogen bulbs for fog application...
  9. #429
    XV and NB+ has various claims pag dating sa improvement over stock halogen bulbs. For the benefit of those wanting to upgrade I posted output comparo several pages back:
    stock vs. XV
    marami pang naka post na pix dun including my comparo on pnp HIDs and hid projectors.
    I've tested both XV and NB+ considerably as I also have this in my stock. I just don't want to sell it and swallow the performance claims hook, line and sinker. Based on actual output, yes there is an increase in intensity and based on lumens output this is only 15-20%. Would I recommend this upgrade? for a few thousand pesos, yes and specially those with old halogen bulbs already. For new cars with new bulbs, I would think twice because the increase will not be significant.
    #430
    Quote Originally Posted by kidgz View Post
    sir xtian
    tnx
    godbless
    Sir, please text me for faster transaction. Thank you!
    0917-7578484
    0922-8588484
    #431
    Ok sir. I've already emailed my supplier. I am just waiting for his response. I'll update you as soon as I got email from him. Thank you sir!
    Apr 2012
    #432
    Pag nag lagay ba ng osram nb or philips xv sa projector magiging oem look ba? Ung parang naka factory hid? Thanks!
    Sent from my GT-I9003 using Forum Runner
  13. #433
    hindi bro, malayo output ng HID bulb sa halogen bulb, 3x more ang HID bulb. NB+ or VX will give you 15, at most 20% increase.
    Apr 2012
    #434
    I mean, ung pag ka white ng projector. Kahit same output ng normal bulb bsta mjo white-ish sya.. :-)
    #435
    NOW AVAILABLE! OSRAM NIGHT BREAKER PLUS LIMITED EDITION! LIMITED STOCKS ONLY
    Sep 2005
    #436
    how much sir?
  17. #437
    Quote Originally Posted by MikkiW View Post
    magiging white ng konti coz better ng 10-15% output ng XV but dont compare to HID bulb. Mas malakas kasi output ng HID bulb so 4300k talaga yun.
    Apr 2012
    #438
    So ano mas okay? Osram nb+ or philips xv? Parang same lang naman sila? If changing headlight bulb, do we need to align it again? Im worried baka pag nagpalagay ako hindi maganda ung cut off...
    Aug 2012
    #439
    *MikkiW: based on the photos of garyq, negligible ang difference between Osram NB and Philips XV.
    both bulbs have positive reviews and had received awards abroad so it's a draw for me. both brands are OEM brands.
    i bought Philips XV last year since mas mura ko siya makukuha vs Osram NB. sa Amazon ko siya binili. made in Poland ung bulb.
    anyways, kung alin ang mas mura mong mabibili, yun ang kuhanin mo. just make sure genuine ang item.
    #440
    sir kung habol mo eh white effect like the HID, you'll be disappointed with XV or NB+ kasi di sila as white as HID. look for other philips bulb na blue ang color ng bulb kasi the blue color will make the light as white as HID. Bought and used that before but cant remember the name of the philips product. Parang blue vision ata yun. White sya pero less lumens, meaning not as bright as the XV or NB+. mas mahal din sya.
Philips X-Treme Vision Vs. Osram Night Breaker Plus
