Autoline in Makati has Xtreme Vision H4. P1.9k ata.
mukhang maganda yung Osram NB plus, problem lang wala pa yatang H4 na kelangan ko... Kita ko pa lang is H1 for 1,200 sa sulit.com
^ Sana nga may makita Ate ko sa Singapore or sa KL na Osram NB or kahit yung Philipps na yan. Next week malaman ko na.![]()
Fasten your seatbelt! Or else...Driven To Thrill!
sir pag affordable pasabay naman kung pwede....hehe....isang tambling lang ako papunta sa inyo or magkita nalang tayo sa HQ ni INSO....![]()
I am not sure if it's the same one, but years ago I tried both PIAA Plasma blue and Super Plasma. Though both gave me the whitish light, both were not bright enough, even though I bought the 80/80 version. Both also burned out pretty quickly, less than a year.
I got this over 10 years ago pa, at that time I bought it from CATS (when it was still an aftermarket auto shop), the Plasma blue were around 5k for a pair and the Super Plasma were around 6.5k then.
Since then I have not bought any white bulbs since the coating seems to make them burn out too quickly and so will be a very expensive experience.
I am now planning on getting the Philips X-treme, since it doesn't have that coating, which should make it produce more light but not neccesarily a whitish blue light.
mag bros, sa mga naka xtreme vision na, musta naman po output? Pwede po pa post ng pics? TIA
osram NB both low beam got busted after 2yrs+ of use. i went to Cartronics along del monte ave. to buy XP, then i saw xtreme w/c cost 1,500 same as XP. kaya ayun x-treme vision na binili ko. got to do some test pa, kanina ko lang kinabit.
Got my H4 Extreme Vision +100% in C3 4x4 for P. 1,800.
Saw H4 Extreme Power (not Vision) in ebay.ph for P. 1,500
Cartronics del monte ave. malapit sa shell station bago magbridge papuntang frisco/roosevelt. check nalang sa wikimapia.
nasa crosshair. hindi pa pala indentified. madaming autoshop na tabi-tabi dyan.
Wikimapia - cartronics del monte ave.
mura na pala yung 1,500 na benta nila kaya ng tumawad ako sabi ni ate emie mura na daw yun. duon din ako bumili ng osram NB 2 yrs ago 450/each bulb.
*peejay07
wala pa time for pics. nightdrive w/o rains concrete/aspalt road mas madilaw sya compared sa NB.
sana may NB Plus sila.....parang mas ok kasi yung NB plus....what do you think?
Night breaker is whiter but Philips X-treme vision is brighter.
NB=Porma
PXV=Performance
