Results 1 to 10 of 34
- Jan 2009
- 817
October 27th, 2010 07:45 PM #1Stumbled upon this on google, as I was doing some research on retrofits:
DIY coke can curved into a U-shape to prevent reflections from the reflectors going in an upward (glare) direction, therefore the only light that should be reflecting off the reflectors is light shining in a downward angle.
Looks something like this:
Or if you wanna be real professional about it it can be made professionally like this:
Not a bad cut off neither:
Here's some links:
http://www.elantraxd.com/forums/show...-glare-shields
http://forums.mg-rover.org/showthread.php?t=293708
http://www.hachiroku.net/forums/showthread.php?t=700
http://www.clubcivic.com/board/showthread.php?t=186085
Or just google it.
So what do others think? A good idea or a recipe for disaster? Judging from the links/feedback, so far so good naman...
October 27th, 2010 08:13 PM #2
May bad side din yang Glare Shield.
May Glare Shield yugn Philips HID na kinabit ko sa Tucson, H4 type.
What happened?
Nagka-burnt mark yung Headlight reflector.
Pics:
- Jan 2009
- 817
October 27th, 2010 08:21 PM #3
- Jan 2009
- 817
October 27th, 2010 08:46 PM #5Hehe wow that quick huh... maybe the glare shield was too protective and heat was being trapped inside?
Right now I just finished making a pair using coke cans fixed it into the HID casing and okay naman sya, no more glare and may cut off-line na, unlike before - sabog.
Pics to follow...
October 27th, 2010 08:55 PM #6
Siguro..
Tsaka kung mapapansin mo sir, lahat ng buga ng HID concentrated sa taas, so ang mangyayari doon pupunta lahat ng heat..
October 27th, 2010 09:52 PM #7
Mazzipino, updates sir if nagkaron din ng burnt marks yung reflector. Parang kay SG.
- Jan 2009
- 817
October 27th, 2010 10:36 PM #8Okay, I've done it na. My neighbor (who helped me) thinks I'm a bit crazy to use a coke can but so far so good....
These are the pics I took before I went out and drove around. I drove for around 45mins with HID on all the time:
Eto sya when on: (yes needs some tweaking)
In terms of glare, wow I can stare into my headlight now even for only a few seconds, before hindi talaga pwede, masakit sa mata.
In terms of light output, I estimate it to have decreased by around 20-30% but it's still good, the cut-off is visible when taking corners. the important bit is very minimal glare for oncoming vehicles.
In terms of the cut-off, hindi sya straight na straight as in projectors but friendly naman sya for oncoming vehicles (i didn't get flashed at all).
Oh and walang burnt marks sa reflectors, none at all - maybe because the can is more open than the philips (which is closed ata).
Tomorrow I'll take pics of the glare, light output etc...
Anyway not sure if I'm going to leave it there for the long-term, I'll give it a few days and see if any problems arise. If wala, I might think about having this made:
para mas maganda and hindi halatang 'cheap DIY job' hehe.
problem i can foresee in short/long term future is heat issues, as mentioned before heat is now restricted to one area this could shorten the life of the HID and it's surroundings.
- Jan 2009
- 817
October 27th, 2010 10:51 PM #9Good read:
http://www.mitsunation.net/showthread.php?t=2015 - particularly 'potential solutions part 2'
Yes the best way to go is definitely projectors but life's full of shortcuts, and this shortcut in particular might just be feasible
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
