Page 3 of 19 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 361
    Dec 2003
    #41
    Quote Originally Posted by odell
    wow.. alam ko nga 65K pa. san mo nakuhau n iyo parE?
    ganda nga ng buga niyan :D
    actually yan ang selling price, dealer price mas mura, supplier kc Wurth Philippines
    #42
    ahh.. tapos sabe nga 6 years warranty daw.. san mo kinabit parE?
    Dec 2003
    #43
    sa Gen2 V, bimmer sana kaya lng H7 kc di pwede H4 hehe
    #44
    may h7 din yan.. wala daw ba? hehehe
    pero madugo maxado un gnaun kalaking pera para sa ilaw dont you think? hehehe
    Dec 2003
    #45
    onga e kaya di na umorder uli haha
    #46
    Quote Originally Posted by zidane21
    ot: basta nakakaasar minsan yung mga todo ang pagbukas ng headlights (to some pati foglights!!) na naka-HID!! Sakit sa mata!!! nakakasilaw!! can be a deadly source of accident to other tsikoteers!!
    Headlight beams not properly aligned. Kahit na bagong sasakyan di naman ayos ang alignment.
    Apr 2004
    #47
    dropping a hid retrofit kit on halogen projector headlights is good but not good enough,... kung us dot specs yung headlights (or stock)mo, either projector or non projector eh hindi parin maganda yung beam pattern, unless you retrofit it with the projectors from an oem hid equiped headlight, like those of the bmw hid projectors... another posibility is using European code projector headlights.... ganito ang beam pattern ng E-codes ___/___/
    FICTION: "9000K is brighter than 4200K (factory HID)"
    FACT: 4200K is the brightest output. As the "K" goes up, the lumen/brightness goes down
    FICTION:"10000K will be dimmer than halogen"
    FACT: HID is still brighter than halogen.
    FICTION: "Philips HID kit is made by Philip in Germany"
    FACT: Ballast are made by HELLA! Philips (nor Hella) DO NOT make aftermarket HID kit. Philips (and Hella) forbids and condemns any company who uses their ballast for non-factory application
    http://www.hella-press.de/docs...2.rtf (WORD DOCUMENT!)
    FICTION: "BMW uses Philips, so they are the best"
    FACT: Philips & Hella / Osram / Matsushta (<spelled ..hita) components that came stock on your vehicle are the best because they are designed specifically for your vehicle. If you take the same components and apply them to a different vehicle, then it is not THE BEST solution anymore
    FICTION: "Philips/Hella components are from Germany"
    FACT:The originals were, but almost all of the ballasts out there today come from Asia! Does Hella make ballasts overseas? No, the original design and layout has been copied over and over again! How confident are you in believing the ballast is brand new from the Hella of Germany?
    http://faqlight.carpassion.info/
    Dec 2003
    #48
    how bout Wurth? they cost more than philips or hella.
    Sep 2005
    #49
    Quote Originally Posted by BlueBimmer
    Was it wurth it? Hehehe
    Sa ibang bansa kapag HID kailangan merong headlight washers at suspension-based auto levelling, para hindi makasilaw ... kaya mahina ang P100k, pwera pa HID.
  10. jagxtrm Guest
    #50
    Quote Originally Posted by alwayz_yummy
    so it means that all vehicles that comes with projector lights but with stock halogen inside (04 local spacegear, Mazda 3&6, 1991s delica/96 local L3 exceed, etc) and projector light convertion kits for corolla, civic, lancers, etc are ok for HID fits?
    up ko lng po ang thread na 'to...
    ask ko lng kng ganito ba na headlights are HID-ready? (with 'cap')
    ==Ford Everest==
    kc sa Innova hindi cya HID-ready (walang 'cap' sa bulb) at kitang-kita yng halogen bulb sa loob...
    ==Toyota Innova==
    #51
    Both aren't.
    Only projecter lens housing are.
  12. jagxtrm Guest
    #52
    thanks sir theveed! :D
    #53
    click niyo nalang for larger picture...
    yung nasa left ba ang projector? yun kasi ang low beam ng mazda3 eh...
    any suggestions on what brand is ok, yung tried and tested na? thanks!
    #54
    Yung nasa right (center) ang projector.
    Just think of projector lenses as the same ones you see sa PROJECTORs na ginagamit for presentation, home theater etc.
    Kung may parang crystal reflectors, pang halogen yun dahil di nakaka project ng beam ang halogen bulbs.
    #55
    thanks theeved!
    Aug 2005
    #56
    Projector some kinda circular lens within kagaya ng BMW. prehas sakin..
    yung BMW di talaga makasilaw sa mata IDOL.
    so what i understand is that yung hindi nka projector type hindi dapat magpakabit ng hologen type kasi nakakasilaw at accident prone?
    Aug 2005
    #57
    uhmmm sakin hindi ko pa nilagyan ng higher bulbs.. stock lng to sir theeved..
    ito sir theeved bagay HID nito?
    #58
    The-Veed po hehe...
    Yes, yung nasa inner na dark lens housing ay projector.
    #59
    how about the brand BLESK hid? Made in japan ang ballast.
    #60
    a very good read. lalo na sa yung mga may balak mag HID conversion
    make this a sticky please
Hid Faq
