Page 18 of 19 FirstFirst ... 8141516171819 LastLast
Results 341 to 360 of 361
  1. #341
    oliver: you either change the bulb or the ballasts. Nothing to do with the AFS. Pls see www,hidretrofit.net. That's a simple fix
    #342
    May AFS na ba ang 2008 Lancer EX MX?
    #343
    Thanks garyq, check ko..
    Shok, first batch ako ng mga lancer mx noong unang panahon, 2.0 pa mga makina at CBU from japan...busog pa ang mga MX noon.
    #344
    Boss gary, meron bang stock bulbs? Parang upgrades yung mga nakita ko..i just want to stay stock sana...
    Jul 2011
    #345
    Boss, normal ba sa self-levelling HID headlamps ang medyo nagfi flicker ng itsy bitsy tiny bit kapag nalulubak?
    I've read kasi online dahil daw yun kasi suspended yung projectors kaya gumagalaw kapag nalulubak.
    Is this a normal thing or I should talk to my dealer?
  6. #346
    oliver: meron stock d2s
    great: it can move a little bit either meron self levelling or wala
    #347
    Quote Originally Posted by oliver1013 View Post
    Ayos. Expect ko sa GT/GTA lang meron.
    Anyway, tama si Gary, walang kinalaman ang AFS sa problem mo. Bulb or Ballast lang ang papalitan nyan. Nagswap ka na ba ng bulb from left to right para matingnan kung bulb o ballast ang sira?
    #348
    Quote Originally Posted by greatauror28 View Post
    Beam shaking or flicker patay sindi ng mabilis?
    Kung beam shaking, mukhang normal, pero kung patay sindi ang ibig mong sabihin ng flicker, patingnan mo na sa dealer.
    Yung auto-leveling naman may motor lang na nakakabit sa up down adjustment screw diba? same mounting points and adjustment method sa mga walang leveling motor.
    Continuous self leveling ba ang sa Kia? Meaning nagseself level sya habang nagdridrive ka?
    Sa Corolla kasi, mag self level sya as soon as nag-on ka ng headlight depending on vehicle load. Then fixed na sya right after. Di ko napapansin na nagcontinuous self leveling sya. Parang magwear out agad yung adjustment nut sa loob ng headlight kung ganun.
    Jul 2011
    #349
    Quote Originally Posted by shok View Post
    I believe self-levelling only acts upon startup when it detects a heavier load on the back, the headlights will point a bit downwards just to compensate for the sagging behind.
    I will report it to the dealer because mine is like flickering in a sense a medyo kumukurap yung HIDs.
    Feb 2014
    #350
    Guys, yung hid ko pag matagal ng naka bukas biglang di na gagana yung high beam. Ano kayang cause nun? Thanks in advance po.
    #351
    Quote Originally Posted by specialtikoy View Post
    Anong klase ba ang HID setup mo? Projector type na bixenon, H4 bixenon na telescopic, H4 na HID low + halogen high, or Single beam HID + stock halogen high beam?
    #352
    Yun nga ang napapansin ko sa autoleveling. Kapag on ng HL then puno ang sasakyan, automatic niyang ibababa yung beam kung pinatay sya ng driver lang ang sakay previously.
    Ang di ko napapansin ay kung ako lang ang sakay tapos binuhay ko yung HL, syempre di yun magaadjust. Then pag may sumakay ng 3 sa likod, magaadjust ba sya ng hindi ko pinapatay at sindi yung HL? And same kase din kung puno naman at bumaba na yung mga pasahero. I have to try this out.
    Ang iniisip ko, dapat tuwing stationary ang vehicle, magaadjust sya ng kusa kung buhay ang HL, kasi pwedeng may bumaba at sumakay habang nakatigil.
    Tama, ireport mo na sa dealer kung pakurapkurap. Bulb, ballast or power delivery issue yan.
    Feb 2014
    #353
    H4 na telescopic sir
    #354
    Kung namamatay ang ilaw kapag naghigh beam, baka sa relay harness.
    Kung di namamatay ang ilaw pero hindi nagreretract to high beam position, baka yung high beam solenoid ang may prublema na kapag naiinitan nagoopen na yung coil or yung connection ng high beam solenoid hindi maganda.
    Check mo din yung voltage ng high beam solenoid input kung meron using voltmeter.
    Wala kang balak mag projector retrofit? Projectors, shrouds at bulbs na lang yan kasi may ibang components ka na naman.
    Mas effective ang lighting at walang glare sa kasalubong kung tama ang alignment ng beam.
    Feb 2014
    #355
    Thanks sir. Baka nga dun sa solenoid na nga niya kasi di namamatay yung low beam pag nag hihigh beam ako. Bale ang solenoid lang kailangan kong palitan dun sir? Pinag iipunan ko pa pa retrofit eh, may kamahalan eh hehe pero yung ginagamit ko naman daily naka projector na
    #356
    Alam ko buong H4 bulb ang papalitan kasi built in ang solenoid nun.
    Kung mag DIY retro ka ng HID projector, may mga nakikita akong mini H1 at Q5-R sa olx. Mga 3.5-5.5k na budget pwede na.
    Posted via Tsikot Mobile App
    Jun 2014
    #357
    Saan po Shop nyo?
    Mar 2015
    #358
    So what his the most bang for the buck HID plug and play kits?
    Apr 2015
    #359
    Help here, where can i buy for toyota vios 3rd gen HID projector type bulbs? thanks
    Apr 2015
    #360
    good day guys, where can i buy for toyota vios 3rd gen HID projector type bulbs? thanks
Hid Faq
