Page 14 of 19 FirstFirst ... 4101112131415161718 ... LastLast
Results 261 to 280 of 361
    Feb 2007
    #261
    +1.
    naka-telescopic hids din ako on a regular halogen (clear-lens) headlight and di sya nakakasilaw coz natatakpan ng diffuser yung buong lower half ng hid bulb including front. kaya yung beam pattern ng ilaw is much the same with the standard beam ng halogen bulb.
    Jan 2009
    #262
    Sa China (actually Shanghai and Nanjing) nearly all taxis I saw had projector type HIDs. And private vehicles were using similar projector type HIDs.
    Kapansinpansin na walang glare sa incoming traffic even when almost 80% are new cars and these cars all use projector type HIDs.
    Most cars in Shanghais were european (VW, Audi, Volvo, BMW and Mercedez Benz).
    Dito sa Pilipinas at sa QC puro HIG (High Intensity Glare!).
    Feb 2007
    #263
    marami kasi nagkabit ng non-telescopic hids kasi mas mura and/or tinatanggal nila yung diffuser ng bulb para masulit nila ang liwanag ng hid. di nila naiisip ang safety hazards na nagagawa nila to other drivers. very irresponsible...
    Jul 2006
    #264
    Mga sir, ano po ba ok na HID? I'm planning to install HIDs on my new Montero Sport. I want the 6000k but how could I find a HID set with low glare? I only want to install HIDs on my low beams. Can you recommend to me a shop? And what brand will last for many years? My budget is PhP 10k.
    #265
    Walang problema sa montero sport kasi projector na yung OEM headlight assembly nya. Significantly low na yung glare dahil dito. My dad had HIDs installed on his MS, and di naman ako nasisilawan.
    Jul 2006
    #266
    Quote Originally Posted by ssaloon View Post
    It means po ba that it is already telescopic?
    Dec 2004
    #267
    telescopic hid means h4 type bulb wherein both low and high beam are hids and that there is an actuator which pulls and pushes the bulb to where you want to use it. if gusto mo bright, then hinihila ata ang bulb papasok ng konti. i may be wrong pero parang ganon ang pagkakaintindi ko ng concept ng telescopic. kaya naging low glare ang hid sa projectors kasi nakatutok ang focus ng ilaw unlike sa mga frosted/fluted na lights na hindi naman talaga meant for hids. if you want to change your lights to hids, check what kind of bulb you have. if it is a single beam bulb, then just get the equivalent hid kit for it. no need to have a budget of 10k especially if you already have projectors. most likely half lang gastos mo. most likely ha? :D
    Jul 2006
    #268
    so anong ok na brand ng HID? i'm thinking of xenonworx or vtxhid. nakita ko sa isang thread na yung xenonworx 11860 price ng single beam, tapos yung vtxhid 10k price single beam din. dun ba sa mga binanggit kong price kasama na dun yung ballast?
    #269
    A shop near our house was offering me VTX 4300k for around 6k with 1 year warranty. So medyo pricey ata yung quote sayo.
    Complete set na yan with ballast, igniter, bulbs, etc.
    I suggest you stick to 4300k. My dad's MS has a 6000k kit installed, nabibitin ako sa ulan/asphalt roads.
    Apr 2009
    #270
    Nag pa install ako kanina VTX HID 8000k and cost nya ay 6K complete set para sa low beam ng swift ko. ok naman ang buga nya. Warranty nya is 2yrs.
    #271
    but the question is... how much glare does it emit?
    Jul 2006
    #272
    nagtanong po ako kanina sa c3 audio sa banawe kung magkano yung vtxhid. sabi sa akin mga PhP 4800, kasama na ballast. medyo kinabahan ako kasi baka low quality. xenonworx po ba saan meron sa banawe area? ang alam ko lang sa street tech pero di ko alam kung saan yun. give me some inputs po.
    Jul 2004
    #273
    VTX HID is a good brand. Matagal na yan so no worries.
    Sa street tech, they have DK and xenon worx ata. Not sure pero I was there the other day grabe less than 4,000 nalang ang HID. Nagpakabit ako ng HID last August lang 4500 pa ata ang HID.
    Street tech is around 3 or 4 stores away from Jetcar.
    Pag galing sa Q. Ave(Heading towards welcome rotonda) Turn right * Banawe (Mcdonald's) then go past 2 intersections. You will see Jetcar and Street tech sa left side na hilera ng shops
    Feb 2005
    #274
    P4,800 for single beam I assume? Cause their telescopics (H4 hi/lo) cost 6k...
    #275
    Don't base the quality just on the price ..... base it on feedback it gets!!!!!!!!
    http://www.xenonoptics.com/comments.php
    just in case I could help.
    email info*xenonoptics.com or ym id xenonoptics
    #276
    mga sirs just want to ask if DK HID's are good? any feedaback sa mga meron nito. Thanks.
    Saka recommendation ng mga shops or persons kung saan maganda kumuha.
    #277
    Nakakabili ba ng HID ballast ng isang piraso lang at saan? Thanks
    Jan 2009
    #278
    Any recommended HID places from the South? (ie. Las Pinas, Alabang, P'que)
    Jul 2006
    #279
    Question: If I put HID on my Montero Sport, what will happen to the hi beam?
    Feb 2007
    #280
    it'll still be halogen since they have separate bulbs unless you also upgrade your hi beam to hid.
Hid Faq
