Page 11 of 19 FirstFirst ... 789101112131415 ... LastLast
Results 201 to 220 of 361
    #201
    Quote Originally Posted by batang_raon14 View Post
    Yes Sir wala pang kasamang ilaw, pero may lagayan na siya. Lalagyan mo na lang talaga. Yung HID ko po bi-xenon po. And yung solenoid e naka-install na sa assembly mismo (which is 9k), na iko-connect na lang yung wire sa HIGH ng stock wiring niyo. So kung gusto niyo po mag-HIGH, yung stock switch niyo lang din po kailangang gamitin.
    Yung sa angel eyes kasama po siya sa shrouds (takip ng projector assembly), alam ko isa lang yung supply ni Tim so kung ano sinalpak ko saken eh yun din. Bri_g though of Toyota Club may have a different set though. Bright po talaga siya kasi 12 LED's po yung hininang ko per shroud.
    yung Bi-Xenon po, applicable po lang ba ito sa specific projector type?
    #202
    Quote Originally Posted by rion View Post
    Yes Sir, basically may two types yan, single projector types and bi-xenon projector types. Yung single walang solenoid while yung bi-xenon naman po eh meron. Eto po sample pic ng solenoid:
    Generally single projector types are cheaper compared to bi-xenon ones (solenoid kasi nagpapamahal)
    Eto po Sir sample vid niya for your reference:
    [ame="http://www.youtube.com/watch?v=jvxUWYKA3_Y"]YouTube - Bosch E46 Bi-Xenon Bixenon Projector[/ame]
    #203
    ah, ayun pala. salamat B_R.
    galing ng gawa mo. awesome and brave.
    #204
    Thank you Sir.
    Apr 2008
    #205
    b_raon, pwede kayang ipalit ang headlight nito sa starex ko, jac refine ang name ng van na to. may nkita na ako yesterday nyan sa trinoma.
    http://www.productioncars.com/galler...C&model=Refine
    http://jacen.jac.com.cn/jac/showDocu...1000def9f70136
    diba projector na rin cya? TIA
    #206
    Bago lang po ako sa mga bagay katulad ng HID. I'm planning to buy a 6000k kit for my 2008 altis. May kailangan pa ba akong bilhin para hindi 'kalat' ung ilaw ko at hindi nakakasilaw para sa mga nakakasalubong ko?
    #207
    Quote Originally Posted by rltc View Post
    projctor headlight assemble po cguro or itest nyo muna kung maganda ba ang cut-off ng reflector type housing nyo katulad sa 1stgen altis
    #208
    salamat po sir! last question. how much would it cost me if ever I put a projector for my car? and where?
    #209
    I suppose this is a good update with regards to installing projectors on your stock headlights:
    http://tsikot.yehey.com/classifieds/...t/47113/cat/48
    Advantage is reversible to stock siya. Pero ang most probable disadvantage siguro nito ay yung clarity ng beam at cutoff. Lens type siguro ay either dual or singlet as opposed sa triplet na gamit ng ibang manufacturers. Ang liit masyado though, di rin pansin na naka-projectors ka unless gabi, pero will do for those who simply wants to have projectors on their cars.
    Up for the one selling this and sorry mods for the plug.
    Aug 2008
    #210
    hi just a new member, planning to put hid on a suzuki swift. any suggestions?
    Aug 2008
    #211
    Jan 2008
    #212
    retrofit HID projectors first or stick to halogen bulbs
    Apr 2008
    #213
    Hi,...Schematic Drawing to help better understand HID + Projector Head Lamps
    Projector:
    http://tsikot.yehey.com/forums/album...&pictureid=270
    Without shield:
    http://tsikot.yehey.com/forums/album...&pictureid=273
    Without Lens & Shield:
    http://tsikot.yehey.com/forums/album...&pictureid=274
    Here's someone who DIY his own HID
    http://forum.ih8mud.com/80-series-te...eadlights.html
    #214
    thanks, you know, when we bought a pair of projector on banawe, we have no idea what ride it came from. we only knew, we can fit it on our ride as a fog light. when we saw the shield, we taught sa taas dapat naka place...
    boy it glared bad... I almost gave up. buti nalang na try ko lagay sa baba.
    #215
    san sa banawe at magkano yung projector mo sir rion? picpicpic!
    #216
    2k for the pair sir s_quilicot. 2.5 inch wide lang.
    DIY lang, the result was a mess, good thing hindi makikita sa loob.
    the cutoff:
    #217
    the cutoff:
    sang sasakyan po kinabit?
    kamusta ang bato?
    pwede bang pang headlight?
    waterproof?
    #218
    san banda sa banawe?
    DIY ba ang cut off?
    #219
    it's for toyota van. this shot was taken while the ride is higher, pababa kasi grahe palabas eh.
    sa bato naman, not too good because of the location. imagine using a flashlight but aim with the lowest height, yung mga bato sa daan will make a longer shadows and so on... most of the light are aimed sa roads na.
    kasi kung mas mababa ang light source, dapat mas steep ang aim to avoid glare... it's about avoiding the headlight throwing in your face. the cutoff is good but because of the installation limitations, the throw is splitting opposite a bit. there is no left or right cutoff like the delica projector, making the aim must be even lower.
    you can use it for headlight if the height is the same with heads not fogs. but single low beam lang siya.
    I am not sure with waterproof, but it seems very secure.
    stock na po cutoff, but you can turn the cap to 180º along the cutoff, so puwede taas o baba ang cutoff.
    I'll ask my bro where he bought it, later tommorow.
    #220
    the shop is Nankai.
    but If I have money to spare, I would prefer those bi-xenon kits instead.
Hid Faq
