Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Car Lights and Lamps Talk Thread, h4 light booster? in More Than Looks; guys liliwanag ba yung h4 headlight ko pag nag upgrade ako ng socket / wiring / relay? nakita ko kasi ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Like Tree2Likes
Thread: h4 light booster?
  1. #1
    Tsikot Member cokezero's Avatar
    Join Date
    Aug 2010
    Location
    Paranaque
    Default h4 light booster?
    nakita ko kasi sa internet may mga light booster na ganun lang ginagawa
    hindi ko sure kung effective..
  2. #2
    Forum Moderator ghosthunter's Avatar
    Join Date
    Location
    Metro Manila, Philippines
    Default Re: h4 light booster?
    Quote Originally Posted by cokezero View Post
    There will be some brightness gain especially if the vehicle is getting old.
  3. #3
    Running on Empty...
    Join Date
    You can go to Banawe and buy one of those Narva relay/wire plug and play upgrade kits (less than 1K), get good 90/100W bulbs (either stock white or all weather), and ceramic sockets (meron sa ACE and True Value).
    Another is to also check your headlight lenses if they need to be cleaned and readjusted for an optimal aim.
    Make sure also your electrical system output is still good. Your suking electrical shop can check that for you.
  4. #4
    Tsikot Member Rank 4 JohnM's Avatar
    Join Date
    Aug 2004
    Location
    BGC (tambay)
    Yep a Narva relay kit and Philips Xtreme Vision (H4 stock wattage) did wonders on my old car. Didn't go with the higher wattage bulbs though since I was afraid of burning up the reflector.
    A PROPER HID conversion will also help.
    And remove your windshield tint if you have one
  5. #5
    Join Date
    Aug 2010
    Location
    Paranaque
    salamat sa replies
    ahh paano pala kung stock watts yung gamit ko? 55/60 lang liliwanag pa rin kaya?
    kasi napansin ko parang magkasing lakas lang yung sealed beam ko dati tska yung h4 bulb na binili ko ngayon..
  6. #6
    Join Date
    Dec 2007
    Yes sir liliwanag pa rin. Ang purpose ng booster ay i-ensure na full load yung kuryente na pupunta sa bulbs. Normally, kulang na ang umaabot sa bulbs dahil sa inefficent (thin) wirings at sa switch. Sa booster o relay kit, mas makapal ang wirings saka gumagamit ng relays para more voltage ang aabot sa bulbs. Usually 10-11 volts lang ang kuryente sa socket ng bulbs sa stock wiring. Aabot ng 11.7 volts ito pag maayos ang relay kit mo, ang maliit ng power gain dito ay malaki ang effect sa 12v sa bulb.
  7. #7
    Nissan/Mazda Fanatic basti08's Avatar
    Join Date
    Oct 2005
    Location
    qc
    try using ceramic sockets
  8. #8
    Join Date
    Dec 2009
    Ceramic socket na ba stock headlight ng hyundai getz 2011?
  9. #9
    Join Date
    Aug 2004
    Location
    BGC (tambay)
    Quote Originally Posted by malleus_ph View Post
    Most likely not.
  10. #10
    Join Date
    Location
    Normally it's just high-temperature plastic socket. Good enough for the job but if you are going to use higher wattage bulbs, you'll need to replace them.
Receive Latest Car Lights and Lamps For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Lights and Lamps Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
