Results 1 to 10 of 10
    Nov 2012
    I know they're turned on during the day,but r aren't they turned off at night?????
    Feb 2009
    Quote Originally Posted by Steveyemd View Post
    the drl are on about half bright when driving daytime without turning headlights on. once the headlights are turned on, it overrides the half bright drl. the same headlights are used for drl and night driving, just a matter of modes
    Sep 2011
    I have mine turned on always at night haha.
    Naka tap lang kasi sa park lights
    Jun 2012
    Meron DRL na multi-function. It has its own controller.
    1. Always on pag running ang makina. Patay sya pag patay ang engine
    2. Sasabay sya sa signal lamps (if activated)
    3. Pag nag turn on ang head lamp, mag dim sya (if activated)
    Meron din DRL na wala ng ginawa kundi iilaw lang sya talaga.
    Jan 2009
    Depends on the car's make and model, and if it's DIY, how it is configured (controller-based or otherwise).
    Modern Honda OEM DRLs in US and Canada uses the hi-beam at reduced power. They're activated with the engine running and the shifter out of Park (for A/T). They're deactivated when you turn on the headlights.
    Nov 2011
    Quote Originally Posted by babynos01 View Post
    lol. useless ng DRL mo. naka off pag daylight. haha
    pansin ko pag LED DRL, half brightness at night
    pag PWM na High Beam DRL, naka off sya at night
  7. #7
    Each country will have its own regulation but for me daylight nga so sa ignition it should turn ON and OFF when you turn on your parklights. Ganyan sa Jazz ko. I think mas maganda naka OFF sa gabi since redundant na when you have park lights. Some will have it sa low intensity sa gabi which will look good on some cars. Basta hindi nakaka abala sa iba, ok naman I think.
    maayos ba yung mga binebenta sa Blade na tag 1k plus lang pero walang control module. direct tap ang +/- wires ng led sa wirings ng kotse. mabilis siguro ito mapundi dahil direct connection w/o the control module. tama ba?
    Sep 2011
    Quote Originally Posted by TheUninvited View Post
    Well, I still enjoy looking at it during night time
    NRL nga tawag ko e, tuwing night lang kasi na ilaw.
    But nonetheless, it still stands up from the crowd. Unique
    Feb 2010
    my civic FD has an OEM DRL. It automatically turns on 3-5 seconds after you release your handbreak and uses 50% (brightness) power of the high beam. It turns off automatically if:
    1. headlight is turned on
    2. shifter is either in P or N position and handbreak is engaged within 5 minutes
    3. you turn off your engine
Daytime running lights
