Using higher wattage ng stock, will need upgrades.
Naka design kasi ang wiring at sockets for stock wattage.
help naman po kung saan makabili ng OSRAM Night breaker 85/80 watts... i need contact number and price. TIA...
Q: I will upgrade to 135watts of all weather bulb, naka ceramic sockets na ako, my question is need ko paba mag upgarde ng wirings? I have stock wirings!!
ingat lang sa high wattage na halogen bulbs, hindi porket naka wiring harness ka na or ceramic sockets safe ka na. think of your reflectors din. in the long run.
parang ganyan ang magiging effect ng high wattage halogen bulbs sa reflector niyo. madami na kasi kami na encounter na ganitong cases.
Sir Xenoptics, ask ko lang if Pag nag Wire #14 and nag ceramic sockets na ako, safe naba ako sa 135 watts?? Wire ng headlamps ko lang ba dapat palitan ng wires? Thanks..
totoo yun sinabi ni xenon na pwede madamage ang reflector. may instance pa nga na pag high wattage, pati housing eh kaya din sunugin pag tumagal
para sa akin it's better to use the all weather bulbs..
umulan man o maaraw maliwanag padin sya.. but that's just me
Ask ko lang po if ano difference ng Osram NB sa Osram Silverstar??
mas maganda talaga kung stock wattage lang para walang maapektuhang wiring.
Im uisng Pure Yellow Hi Low bulb. maliwanag sa gabi :D
guys, will you recommend Polarg or IPF brands for H4 HL bulbs? I can see several models that says 60/55W, but output is 130/110W. Is this true? Will this H4 bulb be brighter than a real 110/90W bulb?
thanks sq.
guys, though I have 130/90W H4 yellow bulbs currently installed, I'm not sure if the harness, sockets, wirings, relays, etc. have been replaced to accomodate the higher wattage bulbs (since I don't know how to verify it by myself). I would like to return to stock wattage to be safe. do you have any brands/models in mind that have the stock wattage but with white light throw? I don't have tints on my windshield, and it's not rainy season. would you still suggest a pure white or a bluish white bulbs? TIA!
