Results 1 to 19 of 19
    Oct 2003
    [COLOR=darkblue]HeLLo,
    I'm driving a Mazda B2500 pick-up. And I want to add some additional lights , which I plan to put it sa front bumper for additional light...
    Ano ang maganda ilagay? na gaganda ..at hindi magmumukhang baguy.
    If I install this light, do I have to add additional relay for this?
    Jun 2003
    Ano ang maganda ilagay? na gaganda ..at hindi magmumukhang baduy?
    --- my suggestion sir if its a b2500 go for hella comets or other driving lights that are similar not too big in diameter and not too thick (but it really depends on your preference after all its your truck)
    YES! you have to
    also try to look for a switch ( if wala ka pa ) one that would look stock would match your dash perfectly
    try to go to surplus shops for the switch cheaper\
    GoodLuck
    iba't ibang klase ang mga aux lights, may driving lights, may flood lamps, may fog lights,
    and yes you must add a relay
    also buy japan switches yung push/pull.
    Jun 2003
    baka driving light lang hanap nya
    baka sakaling makatulong...
    www.hella.com
    then proceed to "light tunnel" and test the particular aux lamp
    eto yong link, sobrang haba kasi, try na lang if it will work
    http://www.hella.com/produktion/Hell...ivingLamps.jsp
    Aug 2010
    my friend is thinking of installing auxilliary lights for their L300FB van.
    1. what shape do you recommend? round or rectangle?
    2. brand?
    3. what size is best suited for L300?
    Aug 2010
    any comment on Hella 500FF Fog Lamp Kit?
  8. #8
    depends yan sa requirement mo with regards to increase visibility and also your budget. That 500FF is ok, I think meron nayan driving lights (narrow-long) output and meron fog (flood type, short but wide). You need a relay for that or buy a complete harness, mga 1-1.5k set and yung switch inside the cabin.
    Aug 2010
    Quote Originally Posted by garyq View Post
    based on the website. complete set na yan. install na lang.
    any idea of the local price?
    which is better round or rectangle ang shape?
    Dec 2009
    You can also try bosch.. Merong bosch auxiliary lights na binebenta mismo sa bosch center sa kabignayan near banawe..
    Personally gamit ko ay 4 bosch compact 100's... Very happy with the output...
    Small yet powerful... Search mo sa net.. So you can have alternatives and comparisons
    Aug 2010
    Quote Originally Posted by miko101130 View Post
    price tag ng bosch per set?
    Dec 2009
    around 2,800 for a pair...
    bosch compacts are for long distance vision, pencil type beam...
    if you go that way, i suggest get the Philips rally type H3 bulb, 100watts per bulb yun... that's around 2000 lumens per bulb...
    Aug 2010
    Quote Originally Posted by trucker111 View Post
    is this available in manila? price?
    sir, have you tried going around masangkay-recto area? madaming auto supply dun. isa isahin mo baka meron.
    Dec 2009
    Sa banawe meron doon bosch service and sales center, probably meron din yan sa masangkay or binondo area, meh area don na tabi tabi sila mga auto parts....
    May 2011
    bosch or hella for cheaper alternative.meron na din led type fog/aux lights.
    Sep 2012
    i am planning to install HID projector type auxiliary light instead to keep the headlamp assembly and stock foglamps untouched, but with better and controlled lighting... please see HID Projector Auxiliary Light Set for reference. parang ganyan sana. for my pick up rin sana.
    any feedback from users?
    Dec 2009
    Quote Originally Posted by taraki17a View Post
    ok yan sir, basta projector para walang glare and maximized light output... DIY lang nyo ba yung pagkabit at install sir? that's a nice mod...
    Sep 2012
    planning stage palang sir, at baka magpapatulong nalang sa trusted shop, para sureness...
Auxiliary Lights for Pick-up car...anong Maganda?
