Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Car Economy and Fuel Talk Thread, Auto-LPG Conversion Thread in Drive Talk; Pag out of town gamitin mo rin pang luto...tipid na agad Sa mga kain Sa drive thru...Mas mapapabilis break even ...
Page 390 of 402 FirstFirst ... 290340380386387388389390391392393394400 ... LastLast
Results 3,891 to 3,900 of 4016
Like Tree11Likes
Thread: Auto-LPG Conversion Thread
  1. #3891
    Darker and Bigger shadow's Avatar
    Join Date
    Location
    I am behind you...
    Default
    Pag out of town gamitin mo rin pang luto...tipid na agad Sa mga kain Sa drive thru...Mas mapapabilis break even mo..
    Sent from my iPad using Tapatalk HD
  2. #3892
    Join Date
    Jun 2005
    Location
    makati
    Default Re: Auto-LPG Conversion Thread
    bakit ang mga taxi pag magpakarga ng lpg, lagi nakabukas ang trunk? wala naman dun ang filler hose
  3. #3893
    Forum Moderator ghosthunter's Avatar
    Join Date
    Location
    Metro Manila, Philippines
    Quote Originally Posted by sirkosero View Post
    They want to check the mechanical gauge attached to the LPG tank. The typeical LED LPG fuel gauge is not too accurate... it just tells you full, 3/4, half, 1/4, empty.
    I am just fortunate my system reads in percentages between 85% down to 12% in increments of 1%.
  4. #3894
    Running on Empty...
    Join Date
    My LED indicator is quite "conservative".
    When i'm doing 10km/L++ average in fuel consumption, here's the sequence of my LED indicator going off as against my trip meter which i reset to zero when i fill up my LPG tank:
    1st LED goes off at the 80-100km mark
    2nd LED goes off at the 130km mark
    3rd LED goes off at the 230-250km mark
    Low Warning (beep and blinking 4th LED) goes off between 250-260km mark
    I can still go all the way to 500km without running out of LPG at this rate (have not encountered running my LPG tank dry). I usually gas up when i hit the 400km mark on my trip meter though.
  5. #3895
    Tsikot Member Rank 2 non-vtec's Avatar
    Join Date
    Jan 2003
    Location
    Manila
    May problem yung LPG sa A33 Cefiro. After engine swap, the LED turned off. Checked the fuse ok naman. What could be the problem?
  6. #3896
    Join Date
    Location
    Quote Originally Posted by non-vtec View Post
    Just bring it back to the installer and let them figure it out.
    Assuming the Auto-LPG kit is still functioning without the LED display, it could be a busted LED module.
  7. #3897
    Join Date
    Jan 2003
    Location
    Manila
    ^Thanks. Called Macro recently but they only do service by appointment.
    BTW I replaced my engine because of constant overheating. When the new engine was installed, there was still an unusual high pressure from the cooling system. And since the LPG kit isn't functioning, I asked the mechanic to bypass the "vaporizer". It instantly relieved the pressure from the cooling system (the upper rad hose is no longer bloated).
    Been two months already and no overheat. My new engine seems ready for LPG. So I'll have the it reactivated asap. I hope the LPG's ECU is still intact.
  8. #3898
    Join Date
    Jun 2006
    Location
    makati
    is it possible that the vaporizer is leaking lpg gas into the cooling system that can result to bloated or ruptured hoses?
  9. #3899
    Running on Empty...
    Join Date
    Quote Originally Posted by shibby75 View Post
    I thought of this before when i had some coolant flow problems but the guy at Greenfuel before said it wasnt the case (i changed my vaporizer though). I cured my coolant backflow problem by changing my radiator cap which was already busted pala.
    I'm getting the itch to convert my 2012 Altis to LPG as well. I drove my LPG'd 2007 Altis yesterday and boy i really love the feeling of gassing up at P25/L and flooring the gas whenever i want to.
  10. #3900
    Join Date
    Jun 2006
    Location
    makati
    29P per liter ngayon. Ano naman kya rason nila? Middle east turmoil? Di naman dun galing lpg.
Receive Latest Cars For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
