Results 31 to 40 of 58
August 26th, 2011 03:46 PM #31
The biggest expense for the D4d over the VVTi engine would be the common rail system should it fail or be in need of servicing.
When we had our manual D4d, it got the best mileage by running at a constant 80kph at 5th gear but its also sooo slow and will make the driver sleepy if youre on an open road such as NLEX/SCTEX. Given the speedo error, its running around 70-75kph real time.
August 27th, 2011 05:06 PM #32
- Jun 2006
- 1,139
September 12th, 2011 11:15 PM #33
Common rail injectors are bound to get replaced as it mileage increases, more so if you use dirty fuels. The injectors costs 20k each, scv pump and fuel pump also needs to be replaced as the car ages.
If your going to keep the car for more than 5 years, your safer with the vvti.
September 13th, 2011 07:06 AM #34
- Dec 2008
- 462
May 21st, 2017 04:21 PM #35With the impending increase of diesel due to excise tax, from a financial point of view, is the diesel still worth it versus the gas given its 100k difference? I was thinking of getting the diesel but with news of 10peso increase per litter in diesel due to excise tax, i am having second thoughts of getting the gas variant instead. I average 9k km/year and plan to keep at least 10 years.
Sent from my SM-G930F using Tapatalk
May 21st, 2017 04:41 PM #36
You're basing your long-term decision on something that isn't even confirmed.
From my experience in the petroleum industry, it's very unlikely that they can implement a 10-peso excise tax. Too much of our economy depends on diesel. All our goods are delivered by diesel trucks. All our roads are built by diesel cement mixers. Most modes of public transport are through diesel vehicles.
And even if you take the excise taxes to be true, intrinsically, the diesel Innova is still more frugal and is much more suited to carrying people than the gas-fed one.
May 21st, 2017 07:50 PM #37
- 52,756
May 21st, 2017 07:58 PM #38
- 52,756
May 21st, 2017 10:17 PM #39Originally Posted by ;1814427
after 6 years, i am happy to note that, aside from the oil and filter changes, my now-12-year-old diesel engine still did not need any sort of maintenance or repair. the odometer is over 120K. i hope my luck holds.Last edited by dr. d; May 21st, 2017 at 10:19 PM.
- Apr 2012
- 3,469
May 22nd, 2017 07:58 AM #40
The backup charger finally arrived. Here are my findings and conclusion at the end:
