Page 14 of 16 FirstFirst ... 410111213141516 LastLast
Results 261 to 280 of 301
    #261
    Quote Originally Posted by ericson21 View Post
    pero si fort 2.5 D4D AT runs 160kph at 3k RPM, pwede na din for me, di naman ako racer, hehe. maganda din talaga si new 2012 fort.
    Kung top speed, ok na rin bro. Acceleration talaga big factor.
    #262
    lagyan na lang ng performance chip, yung plug n play S
    #263
    Pwede rin Devil's Own Alcohol Injection :diablo:
    #264
    Mas ok kung walang modification para walang daya.
    Apr 2005
    #265
    160? sobra na yun bro. ano ba max speed ngayon dyan?
    #266
    Quote Originally Posted by apolq View Post
    A Crosswind can hit 155kph tops, what's wrong kung maabot ng D4D Fortuner ang 160kph ?
    Aug 2004
    #267
    Going downhill. A more realistic top speed for the Crosswind is between 135 to 145 km/h.
    A Fort 2.5 should be able to hit 160 km/h, given it has over 100 hp, and drag is more important than weight at high speeds, but not that much more.
    #268
    Yep. Sa top end, all the fort variants are pretty equal since it is drag limited and not limited by power or gearing.
    However, the time it takes you to reach that speed is what makes the 3.0 variant different from the 2.5
    Feb 2011
    #269
    oo nga, hehe. kayang kaya naman maka 160 nung fort eh. 3k RPM. kaya pa din gang 175-180kph sa tingin ko nga eh nung na drive ko dati.
    Aug 2004
    #270
    It can do 180, but not much more. The automatic transmission has a built-in speed limiter.
    Not that you want to drive a tall heavy vehicle with a stiff and twitchy rear suspension that fast.
    Apr 2005
    #271
    i mean why would you want to drive at 160kph, a bit dangerous. and is it out of regulations na yata.
    Feb 2011
    #272
    yes sir, nung na drive ko sa tingin ko talaga kaya top speed ng 180, pero sundot lang, hehe. naubusan na ako ng kalsado kaya di ko na nagawa hehe. :D
    yeah over speeding na hehe. tinry lang i top speed bro. :D
    Apr 2005
    #273
    is it still stable at 160?
    Feb 2011
    #274
    yes, kayang kaya pa. :D
    May 2012
    #275
    Quote Originally Posted by hinDMaxsiado View Post
    The GTV Monty is only stronger than the 3.0-litre Forty at screaming revs of 4000 rpm, because it can rev-out further. The 3.0-litre Forty's 1KD-FTV is not designed to be an ultimate revver but rather as a well-packaged engine that caters very broadly all throughout its useable powerband even from a low rev of 1400 rpm. It's already giving out a meaty 343 Nm of torque even when it's only doing a total of 700 times per minute pressure combustion at 1400 rpm engine-radial speed (rpm) since it's a 4-stroke diesel engine ---- i.e. a cycle of 1 pressure combustion for every two-revolution of the crank. Pressure combustion is in sequence for each of the 4-cylinders that are connected in 90-degree throws along the crank.
    The GTV Monty is NEVER EVER faster at all than the 3.0-litre Forty even when the latter is just a 4-speed tranny. Kindly see below sir.
    Mas maganda pa rin sir ang gear ratios/ spacings ng 3.0-litre Forty kaysa Monty GTV, and it is faster. This is an excerpt on what i have posted at Toyota Forum in one of the past threads thereat. Hey, you were there nga pala sir! Haha! ;)
    Now if you gentlemen are still in doubt, kindly go to the Engine and Fuel System Talk and click onto the last page of the sticky thread dedicated to Racechip Pro. There's a fine gentleman out there with a modded GTV Montysport and he stated in there that he's making 100 kph at 2000 rpm.
    http://tsikot.com/forums/engine-fuel...05/index9.html
    Ngunit sa dalawang yan mas mabilis pa rin at low-revving ang 2.2-litre Santa Fe R-eVGT sa dalawa. At 2000 rpm the 4x2 Fe is speeding 112 kph, while the 4x4 is speeding at 112.3 kph. In fact it is running 190 kph even when it's only revving 3392 rpm.
    EEW!!! Wag ka na lng mag-thread kung puro trashtalk pati black propaganda ka lng tol at unang una, may Santa Fe ka na buh?? Sa tingin mo mataas ang resale value nyan pag ikumpara ng iba sa Fort at Monty? Haha wala pa rin yang ibinatbat pagdating dyan. Kahit fort o monty, mas mabuti pa kesa sa santa fe. Ung makina na monty ayy, syempre, ung lumang 4D56 na meron ng adventure pati L300 pero pinalitan nila ung head ng 16 valves, malaking turbo, crdi pati VGT din. Alam natin na matagal na yan pag ikumpara sa makina ng SF dahil since 1984 pa hanggang ngayon ay andyan pa din yan. May napanalunan yan international races na kasama ang Paris hanggang Dakar rally. Sa tingin mo, meron bang napanalunang international races ang diesel ng Hyundai?? AYY WALEYZ PO!!! Kaya isipin mo na lng kung gaano katibay ung 4D56 na makina ng monty.
    Nov 2011
    #276
    Montero. Kahit 2012 GLS-V pwede ipantapat sa 3.0V fortuner e. :D
    Aug 2012
    #277
    Montero sport GTV by a 100000000000000 miles
    Aug 2012
    #278
    We owned a 2005 model Sportivo and 2012 Montero sport GT-V. Wala naman kaming reklamon sa sportivo kaya lang medyo mabagal ang acceleration niya. Sa montero naman, Maganda ang handling niya, mabilis, good suspension. If you will compare the montero and fortuner closely, there is a big difference in Montero GLS-V and GTV. Its like you will think of it many times of which model you'll buy. Unlike Fortuner, konti lang ang difference, If im not mistaken, the 4x4 variant vs 4x2 in G model, HID light auto- levelling , aand power seat for the driver. Yun lang. Comapred to the montero, it has GPS navigation, sporty yung loob niya sobra.
    I guess you should go for montero. You'll never regret it. :D
    Sep 2012
    #279
    wait mo nalang fortuner 2.5 with VNT/VGT kung dmo type montero gtv, pero ang direct na kalaban nya ay yung non vgt montero kc mas malakas parin hp/torque ng mga V variant ng montero sa parehas or konti lang difference sa price, pero mas mura ang non vgt montero na kaya parin makipag sabayan sa forutuner 2.5 VNT
    Oct 2005
    #280
    I wonder kung kaya ng Fortuner ang ganitong sporty driving hehehe
    na elibs ako sa Monty dito.
2012 Fortuner 3.0V vs Montero Sport GTV
