Results 1 to 3 of 3
    Feb 2012
    guys pakitulungan naman ako newbie here gusto ko sana bumili ng 2nd hand car.... 2nd car na medyo matagal ko na gagamitin.... dati ko car is 2005 toyota altis 1.8g very smooth ride niya at ok FC at ok na ok vvti. may isa lang problema ang kanyang aircon mabaho at kailangan daw baklasin buo dashboard.... binenta ko na dahil ginamit ko maliit business.... ngayon gusto ko na bumili... pinagpipilian ko nga ay 2007 honda (2005 to 2008) yun luma vs yun 2007 vios (2007 to present)
    base sa akin review (motioncars, vcp at hccp) naghahanap talaga ako reviews bago bumili para di sayang pera ko
    honda city
    -aircon pag major ang problem madali baklasin, repair at linisin
    -pag makina problem medyo komplikado at mahal
    -medyo matadtad daw
    vios
    -aircon pag major problem baklas lahat dashboard ex. compressor... pag binalik dashboard kadalasan may loose connection at may tunog
    -vvti mura daw paayos
    -smooth ride
    please naman po pakitulungan ako tks god bless
    Quote Originally Posted by theinhumanoidz View Post
    honda city
    -medyo matadtad daw
    vios
    -smooth ride
    Between the two, i'd go for the Vios. On the baklas dashboard, the one on the Vios seems easy enough to remove as compared to the Altis; ours has been removed many times and to date wala pa rin kalampag. Also, if you're using the a/c most of the time and don't smoke, you should only see the a/c being opened up every 3-5 years.
    We also have the Vios and City (04-07) in the office and i can say straight out that the Vios is more durable against kalampag and engine/drivetrain miff-ups.
    Feb 2012
    thank you sir vinj vios na kukunin ko.....ang cabin air filter nya ba madali kunin (vios) yun altis kasi ko dati baklas muna dudukutin mo pa di tulad honda bunot salpak lang tks
need advice buying 2nd hand car 2007 city or 2007 vios
