Results 31 to 40 of 41
- Apr 2008
- 6,237
February 4th, 2013 01:21 AM #31The B13 Sentra is a very good car. ECCS engine despite being 20 years old, is still considered decent by today's standards, and fast in this application due to the B13's very light body weight. The only major shortcoming I see with this car is the limited space. If I have to drive this, I will have to slide the driver's seat all the way back, which leaves pretty much no legroom for the rear passengers. But then this is still a 20 year old car so be on the lookout for problems, or you may end up with a bottomless money pit.
- Dec 2012
- 28
February 4th, 2013 11:45 AM #32You sir really knows a lot about cars. Very very helpful on newbies like me.
Madami nga din po akong nakikita na ECCS sa highways dito sa makati, at mukhang ok pa naman ang histura at takbo nila, lalo na yung iba na bagong hilamos (hehe naging habit ko na ang pag-observe sa mga auto sa kalye, tinitignan ko frequency ng mga tumatakbo pa na lumang sasakyan sa highway.. hehe). I think it's settled then, ito na nga siguro ang primary target ko, malaki kasi ang matitipid, pwede ko pa ipunin for the bnew na pinaghahandaan ko.
So what are the major things that I should look at upon viewing?
Any known issues regarding this car? I also plan on getting one this month (depends on my license application hehe).
How about its FC?
Salamat po ng madami sa mga payo ninyo! lalo na kay sir GTi!
- May 2004
- 903
February 4th, 2013 01:00 PM #33alam ko ang common issue sa Sentra is yung menor niya.. minsan nag fluctuate.. pero repairable naman... other than that maganda siya comparable din sa toyota and honda... dami parts... madali maintain... I think gas consumption nasa 8km/l city...
February 4th, 2013 01:53 PM #34
Manual un nakita nyo sir or automatic? Manual nalang siguro kunin nyo ECCS medyo old na din kasi di natin masabi if ok pa un automatic tranny later on, check mo din electricals, power locks and window kung working at sympre engine pinaka importante un, as much as possible maganda makuha nyo un stock pa un lahat sa car wala modification na ginawa un dating owner like suspension saka sa engine...goodluck sa pagbili sir
- Dec 2012
- 28
February 4th, 2013 02:06 PM #35
- Dec 2012
- 28
February 4th, 2013 02:10 PM #36Sir MT po ang kukunin ko. Talagang matanda na ang kukunin ko na kotse, ~20years old, kaya Manual talaga plano.. Yung electricals sir siguro kaya ko pa i-check pero yung engine wala ako alam kaya magsasama ako ng mechanic, wala ako personal na kilalang mechanic kaya baka mag hire for a day na lang sa malapit na talyer dito sa amin.
Kung halimbawa po sir sa body may mods na ok lang ba? Iba na bumper at exhaust.. etc.
February 4th, 2013 02:18 PM #37
kung ok naman pagkakalagay ng mods like bumper ok lang un pampanganda din kasi kung may foglights nilagay na bagong bumper check nyo mabuti un body kung walang bangga, drive nyo kung naka align pagtakbo sa daan di un kumakabig sign din kasi ng may hidden defect un car baka nabangga, regarding sa exhaust as long wala butas ok na un, kung mechanic kung makakasama ka ng kakilala ng kaibigan mo or ng family mo mas ok, nakalimutan ko pa-lift nyo un car kung pede then check nyo kung may leak sa ilalim..pede dalhin yan sa mga gasoline station para ma-lift..wag kakalimutan tumawad hehehehe
- Dec 2012
- 28
February 4th, 2013 02:23 PM #38
- Apr 2008
- 6,237
February 4th, 2013 09:25 PM #39Normally after getting a 2nd hand car, you bring it to the talyer for a thorough maintenance session wherein you change the engine oil, transmission oil, oil filter, air filter and top up the brake fluid, power steering fluid and radiator coolant. Take note of the mileage at which you do this and then change the engine oil every 5tkms and filters every 10tkms. Then you check the brakes if they are worn out, if the brake pads need replacing or even the rotors themselves. If steering doesn't run straight or trembles at high speeds, you have them do alignment and balancing. As they do this they will also be able to find out if any suspension or steering parts need replacement.
Get the most fresh, most original unit you can find. Do not be blinded by "bagong hilamos" or new paint jobs. Some may shine like a new car but are as abused as a cab. The best is to get one that looks fresh, and yet still with the original factory paint job. Considering the age of this car, this is a good indicator that the car was well taken cared of. Stay away from those with heavy modifications and high performance engine swaps if all you want is a reliable, problem-free car.Last edited by GTi; February 4th, 2013 at 09:27 PM.
- Dec 2012
- 28
February 5th, 2013 10:31 AM #40
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
