Results 1 to 8 of 8
- Jan 2005
- 157
August 22nd, 2014 10:03 AM #1I want to preserve trunk space so I'm looking for Underseat subwoofers that is locally available and is priced below 5k maybe 7k max. It has to have,of course, decent bass. Can you recommend good brands?
Anyone has experience with underseat subwoofers?
Thanks in advance
August 22nd, 2014 10:29 AM #2
I was in the same situation before wherein i wanted to increase bass sound in my car, and I too considered the undreseat subs.
I also wanted to preserve trunk space, however i realized that i will not need he entire trunk everyday, but will enjoy a decent sounding subs everyday.
I ended up with a 10inch bazooka type powered V12 subs. I told myself that i can unscrew the cables and just take it out the subs when needed.
Guess what? I never had the need to take out the subs up until i sold the car. Even on long trips.
I
Posted via Tsikot Mobile App
- May 2012
- 44
August 22nd, 2014 11:00 AM #3
August 22nd, 2014 11:57 AM #4
under seat din yung sub ko dati, zubzero brand 10", satisfied naman ako sa bass nya untill medyo nakulangan nako,
nag upgrade na lang ako ng 12" with mono amp... solved
tama si gerald_g, dinaman masyado need everyday yung trunk space
- Aug 2014
- 212
August 23rd, 2014 02:17 AM #5Pls search for "Lanzar subwoofer" in olx. There's an ad there for an 8-inch underseat sub.
September 16th, 2014 05:16 PM #6
I would suggest getting a removable sub instead of an underseat one. To make subs sound loud, it needs air to move around, displacement and power to sound decent. Most underseat subs, would sound distorted coz it lacks the qualities I mentioned. The underseat sub created by Jonz ' SimpleSound is only applicable for cars with a large enough space under the seats like a honda city or the jazz.
- Apr 2011
- 256
September 23rd, 2014 08:45 AM #8
The car audio shop near your place should have one depending on the brands they carry. Here's a list of some shallow-mounted subs and requires a smaller displacement.
Domination ZB
Cerwin Vega SMax
Phoenix Gold SL10
Polk audio MM1040
Powerbass S10T
Saang location po kayo malapit?
high idle RPM at engine start
