Results 1 to 4 of 4
August 16th, 2013 01:43 AM #1
Mga bossing anu magandang brand and model ng 10" na sub na di lalagpas ng 5k?
Nasunog ko kasi yung DD 510 LE ko e.
I'll still use my enclosure, sayang naman kasi.
August 17th, 2013 03:16 AM #2
If you're going to be keeping the box, people can't simply "recommend" subwoofers because different subwoofers behave differently depending on the box. This is why I often tell people who are constructing their car audio setup to first know their needs THEN choose a subwoofer. Because you need to choose which and what are your box specifications FIRST.. THEN you choose a subwoofer driver suitable for your preferred enclosure.
A subwoofer's performance is directly correlated with its box. Put a great speaker in a non-optimal box and it'll sound horrible. That's why we have Thiele-Small parameters for speaker drivers and box calculators.
For example, there are subwoofers that are designed for sealed applications while some are ported. Sealed boxes are way easier.. as you'll be paying attention to T/S parameter Qtc of the box and the driver. On the otherhand, ported applications are a pain as different drivers require longer, shorter, "fatter", or maybe "thinner" ports and all. This affects the T/S parameter of Fc or what we usually call as the "tuned frequency"Last edited by jhnkvn; August 17th, 2013 at 03:25 AM.
- Mar 2013
- 23
March 3rd, 2014 11:28 PM #3
lightning lab WB 10D2 300w rms max 600w or LL1XL 12D2 600wats RMS max 1000w 3.5k lang sya yan gamit ko ngayon. swabe tumunog marami napapa nganga kapag naririnig nila
ang kagandahan sa sub na yan kahit naka Lported box sya ramdam mo ang kick
ng bass kahit love songs, classic slow rock, heavy metal or simply rock music
di flat ang tunog nya sa bass kick pang alternative sa dd or any expensive subs
March 5th, 2014 12:53 PM #4
Boss, if I set the subwoofer's crossover for a low-pass filter of 45hz at a slope of 36dB/octave -20dB gain tapos naka L-ported box ka with a typical tuning of 38hz at Fc.. may mararamdaman kaya akong kick?
Ano po ibigsabihin ng "hindi flat ang tunog"?
Ang experience ko kasi dito masyado malakas yun subwoofer kaya parang may party sa likod. Ano po ang suggestion niyo para mapablend ko sila kasi hindi swabe ang tunog.
