Results 1 to 9 of 9
- Sep 2005
- 22
August 26th, 2007 10:45 PM #1sir, ano suggest nyo na setup for a 1st gen crv? pangit kaya tingnan ung sub box sa "trunk" area? mga 20 k budget ko sirs. il keep the stock HU. pero i was hoping to add seps sub etc... thank you
August 26th, 2007 11:44 PM #2
meron ako nakita sa kotseaudioclub.com na less than 20k nasetup SQ niya ang CRV ng tatay niya e, pero mahirap yun kasi nag-DIY siya nakatago yung sub nakalagay sa wheel space
Sir kung di naman brand conscious ma suggest ko all TARGA setup + v12 amps meron dito tread nun search niyo nalang po pasok dun budget mo
HTH and Good Luck sa project!
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 27th, 2007 09:35 AM #3Lagay mo yung seps sa stock location. If I remember correctly, stock speaker size is 5.25 inches. To hide the sub, put it in the space under the picnic table. You will most likely have to remove the table and replace it with a 3/4 or 1 inch thick mdf board. Best ask a shop what sub and enclosure will fit in that small space. You can hide your amp under the front seat.
- Sep 2005
- 22
August 27th, 2007 08:24 PM #4thanks mga sir. please elaborate on the subs. even with such a small enclosure ( the area under the picnic table) may punch pa rin ba subs ko nun?
- Jun 2006
- 2,605
August 27th, 2007 08:48 PM #5Like I said earlier, you will probably have to ditch the picnic table. The more I think about it, the more it seems likely. Without the table, you will have a speaker grill protecting the sub. Cover it with the carpet and you have a stealth setup.
With a well built enclosure, quality sub (most likely 10 inch) and plenty of power, you should have a great sounding system.
Good luck and tell us how it turns out.
- Sep 2003
- 342
September 17th, 2007 03:43 PM #6ako din po...sana makapag bigay kayo ng site na meron oks na setup for gen1 CRV na sounds..
September 18th, 2007 11:09 PM #7
try this one from our site straight DLS!!!
http://kotseaudioclub.com/forum/viewtopic.php?t=25914
- Sep 2003
- 342
September 19th, 2007 10:30 AM #8thanks po...pero im hoping yung medyo space saving pa rin likod kase isang 10inch sub lang ako plus 2 amp lang that's it... so im hoping na yung sub maitago or mailagay dun sa space sa ilalalim ng floor tapos yung speakers dun sa side..any pix na ganun ang setup and saan oks pagawa dito sa makati area ng ganun setup?
September 19th, 2007 12:16 PM #9
Sale Used JL Audio stealthbox with Pyle sub for Gen 1 CRV (drop-in below picnic table) - (RARE)
- JL Audio Stealthbox - Made in USA
- Pyle Pro Series 1 - Made in USA
- gray carpetting with port
http://i34.photobucket.com/albums/d1...lthboxside.jpg
http://i34.photobucket.com/albums/d1...box-bottom.jpg
http://i34.photobucket.com/albums/d1...lthbox-top.jpg
selling as set po sana sorry wala no pong pics nung nakakabit wala na po kasi yung CRV di ko nakunan hehehe
PM me for pricing nalang po
sa area ko ang dami choices ng emission testing. Bale 500pesos the lowest in my area. Sa iba nasa...
LTO accredited emission testing centers
