Results 61 to 70 of 122
May 18th, 2013 12:09 PM #63
May 18th, 2013 02:58 PM #64
Aspalt works as a deadener. In fact original Dynamat uses an asphalt-base compound. Problem is, nowadays you'll find butyl better as a deadener. Although asphalt is technically cheaper, you'll have to take account we live in a relatively hot environment. It's not unusual for asphalt to peel off after a few months of usage and it will also "smell" inside your car at times.
So.... okay ba performance? Yes. Just not recommended for installation.
May 22nd, 2013 12:35 PM #65
Nagpalagay ako ng Deadening sa Banawe, inabot ng 1k (trunk door). After magawa, tinesting namin, ayun, may rattle pa din sa may trunk pag bumabayo. I decided to buy na lang nung Deadening Material and I was able to find one supplier. Mr. Ted Tamayo (sulit.com), bumili ako sa kanya ng 8 sheets for only Php1,480 ++ tip, then bumili ako ng Heat Gun (Php 1,999.00 Black & Decker) tapos ako na lang gumawa sa auto ko. Tinanggal ko ung iba dun sa una ko pinalagay kasi nilagyan ko hanggang loob nung trunk door. Nilagyan ko din pati ung mga sidings. Nung tinesting ko, ang ganda ng improvement, damang dama mo ung bass. pati sa harap ng auto, ang ganda ng tunog. 3 1/2 na sheet lang nagamit ko as of this moment, next weekend, lalagyan ko naman ung mga door panel and pag mejo sinipag, pati ung ceiling and flooring.
Suggest ko lang sa iba na gusto maglagay ng deadening, bumili na lang kayo ng material and equipment tapos kayo na lang ang gumawa, at least pag may mga kailangan baguhin, madali mo maaayos kc hindi mo na kailangan bumalik sa shop (addt'l gas, labor cost and time). Madali lang naman mag-install, pwede mo din i-search sa youtube kung paano.
^_^ SPOILED
May 22nd, 2013 04:31 PM #66
May 22nd, 2013 07:02 PM #67
Sound Deadening Acoustipad Silver Philippines - 11148472
Cell Number: 09239736001
Bangitin mo na lang sa kanya na ako nagrefer sayo. Sabihin mo ung bumili ng 8 sheets na nakipag meet sa MCdo Alabang Town Center.
Ok na din na bumili ako ng heat gun kc nagcocolect din ako ng mga power tools na pwede magamit sa bahay.
^_^ SPOILED
- Jan 2009
- 123
May 23rd, 2013 02:26 PM #68
- Dec 2012
- 25
- Apr 2011
- 256
August 7th, 2013 03:53 AM #70wala ba talagang source ng butyl based na deadener? kung meron san mura? balak ko palagyan yung ceiling ko. ayoko ng asphalt, for sure matutunaw yun.
