Results 1 to 3 of 3
January 13th, 2012 12:12 AM #1
Hi mga Tsikoteers!
Hoping for your expertise on woodworks design for my APV. Medjo nahihirapan kami mag isip due to limited space..
Unfortunately cant sacrifice the third row seats... madalas gamit sa out of town trips with family and friends.
Details:
2pcs - 8 inch Ground Zero Raw Drivers
2pcs - Ground Zero Raw Tweeters
1pc - 12 inch JBL Sub -- future to be changed to Ground Zero Subs
1pc - Ground Zero Battery (possibly hidden na lang to)
Amps.. (if possible not hidden or if di kaya.. then hidden na lang)
2pcs - Sound Magus 1pc mono, 1pc 4channel
1pc - ads (current on picture ; pwedeng hidden)
1pc - v12 (current on picture ; pwedeng hidden)
here are some of rear pictures for reference..
Thank you in advance for your advices! :wink:
January 14th, 2012 01:38 AM #2
Hmm, from my opinion, you can either make a rack on top of the subwoofer or make a false floor under the subwoofer.
For some ideas, I took an image out of xmarbelx's old CRV woodworks (gotten from KAC's ICE section)
January 14th, 2012 07:30 AM #3
thanks for the tip sir.. i was almost thinking the same pattern.. current thoughts are sub at the bottom, then the 2 GroundZero 8inches on either side on a 'degree' then at center above the sub box is one or 2 of the amps.. slanting also (parang stairs na slanting) its kinda tight though :D
Monk-owned R53
