Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
    Aug 2004
    #21
    Kinda OT: I am learning a lot from this thread. I am planning to replace the stock 6.5s on the Vios with Targa X652Cs para magka-tweeter naman ako (Es don't have tweeters). Very low budget lang so no amps. Replacing the HU is out of the question because the kumander want to keep it as stock as possible.
    Jul 2006
    #22
    Finally!
    I have been also toying with this idea for the longest time.
    Jul 2006
    #23
    1. On the stock HU, press and hold buttons 4 and 6 then power on
    2. Release all buttons and press 4 once (you'll see on the display that it says DSP flat)
    3. Power off then on again and you'll hear a bit more bass
    Will this work on a stock Toyota HU?
    Aug 2004
    #24
    I don't think our stock HU is as high tech as that We can set everything back to 0 after replacing the speakers and work from there.
    Kung di ako tamarin I'll take some shots of the surgery. Planning to do this next month pa naman.
    Jan 2009
    #25
    Probably not. But it shouldn't stop you from giving it a go.
    Apr 2010
    #26
    Targa X652C sa akin, dinirekta ko sa head unit - mahina and onting onti ang bass. Nung nagkaron lang ako ng amplifier saka lang gumanda output.
    Pero kasi generic ang headunit ko, so baka kulang sa power output. Kung sa shop ka magpapakabit at least dun ma-audition mo different speakers within your budget. DIY lang kasi sa akin.
    Aug 2004
    #27
    Kahit normal listening volume lang? No plans of boom boom naman. I just want to improve the sound a bit. Those stock magnets are tiny!
    Jul 2006
    #28
    My music volume is pegged at 8 lang when driving.
    Yeah, just a bit more clarity is what I want to achieve also.
    Jan 2014
    #29
    Quote Originally Posted by markygy View Post
    I wonder if the TS is getting all this information that we are posting.
    Kamusta na ang tunog? Did you at least follow one of our advice?
    sir I will try the method of flattening the dsp settings. im just thinking how tiresome it would be to do that every time i turn on the stereo.
    I have been researching my possible options, something more permanent to address the weak bass without installing a cumbersome subwoofer at the trunk. Im wondering if an underseat powered subwoofer would be the more permanent solution???? Please your advice sirs on this idea. Thanks again
    Dec 2007
    #30
    Quote Originally Posted by Carlo Castillo View Post
    IMO, I think your planning way to far ahead with your plans of installing an under the seat type subs.
    I recommend trying out all the advices posted here first. You might be running around in circles if you didn't get the installation right to begin with. When you're done then that's the time to consider installing a under the seat subs.
help. regrets after upgrading the stock speakers
