Results 21 to 30 of 46
August 20th, 2014 12:15 PM #21
Kinda OT: I am learning a lot from this thread. I am planning to replace the stock 6.5s on the Vios with Targa X652Cs para magka-tweeter naman ako (Es don't have tweeters). Very low budget lang so no amps. Replacing the HU is out of the question because the kumander want to keep it as stock as possible.
August 20th, 2014 01:15 PM #22
August 20th, 2014 01:24 PM #24
August 20th, 2014 01:25 PM #25
- Apr 2010
- 739
August 20th, 2014 01:32 PM #26Targa X652C sa akin, dinirekta ko sa head unit - mahina and onting onti ang bass. Nung nagkaron lang ako ng amplifier saka lang gumanda output.
Pero kasi generic ang headunit ko, so baka kulang sa power output. Kung sa shop ka magpapakabit at least dun ma-audition mo different speakers within your budget. DIY lang kasi sa akin.
August 20th, 2014 01:37 PM #27
Kahit normal listening volume lang? No plans of boom boom naman. I just want to improve the sound a bit. Those stock magnets are tiny!
August 20th, 2014 01:49 PM #28
My music volume is pegged at 8 lang when driving.
Yeah, just a bit more clarity is what I want to achieve also.
- Jan 2014
- 16
August 20th, 2014 05:23 PM #29sir I will try the method of flattening the dsp settings. im just thinking how tiresome it would be to do that every time i turn on the stereo.
I have been researching my possible options, something more permanent to address the weak bass without installing a cumbersome subwoofer at the trunk. Im wondering if an underseat powered subwoofer would be the more permanent solution???? Please your advice sirs on this idea. Thanks again
August 20th, 2014 06:49 PM #30
IMO, I think your planning way to far ahead with your plans of installing an under the seat type subs.
I recommend trying out all the advices posted here first. You might be running around in circles if you didn't get the installation right to begin with. When you're done then that's the time to consider installing a under the seat subs.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
