Results 21 to 30 of 49
August 25th, 2011 02:33 PM #21
nasa mid level na po ito.
yung pagiging outdated sir, nasa pandinig pa rin po ng tao. If you are contented na sa current setup, di na kailangan magupgrade. Dito sa tsikotshop taguig, we usually ask muna kung ano requirements ng customer, kung anong klaseng tunog ang gusto, kung bumabayo ba or yung tipong may maramdaman lang na bass. We also ask kung willing sya mag spare ng space para sa subs , and kung hindi we suggest agad to go for morel or DLS setup.
Morel is from italy, DLS naman is a swedish brand. Meron pang mas high end na model yung morel and DLS
- Jun 2006
- 430
August 26th, 2011 03:02 PM #22Wow this thread came alive eh????
The main reason why I wanted to have an under-the-seat sub is because I don't want my boot to be filled just by that... It also goes without saying that I want my interiors to look as stock as possible...
The speakers of a Mercedes W124 260E can be found on the dash and on the rear tray. Both areas can only fit a 4" speaker... Are there stores in the Philippines that carry 4" full range speakers to begin with???
I have a Nakamichi head unit by the way...
August 26th, 2011 10:10 PM #23
I recently bought an F-150 and currently on stock set up. I want a good Quality sound set up yun Sulit sa halaga. Ayoko na ng
maingay. Dati ang gamit Double Bass na brand Seps with bass. Meron pa ba ngayon na with Mid bass na seps? Nag punta ko sa sucat store nyo wala na pala. Saan na yun store ng Tsikot ngayon.
P.S. Meron pala nag post about Midbass sa taas. So Iguess meron. Thanks
August 26th, 2011 11:34 PM #24
August 26th, 2011 11:57 PM #25
August 27th, 2011 09:14 AM #26
August 27th, 2011 10:44 PM #27
Unit 2, eastpoint bussiness center, east service road, western bicutan, taguig city. Between tesda and bonifacio lang, under skyway.
If edsa then slex, tapos Villamor airbase, tawid ng tulay going gate 3 ng bonifacio, ang then service road, makikita na po ang tsikot shop.
Tsikot.com Shop Hotline: 09053338777 / 09228335588 / 3481728
August 29th, 2011 03:45 PM #28
Wala bang map to your shop? hehe.
August 29th, 2011 07:49 PM #29
Dok, Eto Map, dyan ako kanina kausap ko si Jon wala ako magawa kaya kahit walang stock pumunta na rin ako. Para makita ko yun lugar. Kaya lang hindi ko inabutan si Jedi. Wednesday pang stock.
September 1st, 2011 11:46 AM #30
I have a question about this set up.
MOREL
SEPS- Tempo 6.2 8,700.00
Coax – Tempo coax 6 5,800.00
Tempo 6.2 is a 2-way component right? In this set up Low range will coming from the Coaxial? Thanks
It says CVT daw. For better FC siguro.
Mitsubishi Xforce
