for casual listening levels, pwede na yung HU to power your seps. pero once na i-angat mo yung volume, the audio will sound distorted dahil yung 4x40w power ay peak na yun. i estimate the RMS to be at around 18-20w lang kaya mabibitin yung seps mo. hindi sya full potential kumbaga. just my 2 cents.
i'm currently using a clarion radio 35w X 4. din ko na lang kinabit yung rear speakers ko na 3 way and yung kicker ko na separates. tinimpla ko na lang using yunf fader function nung HU ko. Yung amp ko kasi built in na yung xover so wala ako problem sa pag filter for my 15" freeair subs.
check mo sa manual nung HU kung may sub out yung HU mo then dun mo na lang kabit yung subs mo. itape mo na lang ng electric tape yung isang out just to be sure.
Originally posted by the_wildthing Ako rin pwede magtanong?
Have a stock Alpine TDA-7547(?) on the Corolla GLi 98. Already got an AiNet changer CHA-S624. Speakers are still stock, and no amp yet.
During installation I discovered my HU has only one set of pre-outs for rear.
Was going for the basic setup for clarity and SQ only, so I was originally planning on HU-AMP-satellites and 1 sub. I originally intended to retain my HU and spend on other stuff like speakers and amps, kasi gumagana pa naman.
Now since I only have one set of pre-outs, which is more advisable: a) replace the HU with a newer model with 2 or more preouts, or b) retain the HU and buy a x-over to handle the separation (pwede ba ito?)
One constraint: I do not have a deep pocket, but would like to spend on quality products.
Thanks in advance.
It would be cheaper if you just buy the crossover, pwede din naman ito kung ok pa yung HU mo. the only advantage of getting a head unit is mas mataas na siguro yung output nung HU mo for the speakers and meron na sub out yung ibang HU. why don't u try to trade-in your old radio for a newer model. baka pareho lang gagastusin mo than getting a crossover.
I was able to scour the 'net for spec sheets of the TDA-7547. The RMS output is something like 15Wx4, max at 35Wx4. (PParado, this might give you a clue on what sort of speaker is best if connected directly to the HU.)
On the other end, I found drivers that have spec sheets specifying a range of amp output, so pparado, check out the spec sheet of the speaker you're getting to find out if its recommended amp power is within the range of your amp or HU.
Naisip ko if I get a crossover tapos nasira na yung HU ko, then I will get a new HU na malamang kumpleto na, di na magamit na yung crossover.
Anyway isip isip muna. Baka November pa naman para sa US bili.
by november baka bumaba yung prices ng mga head units ngayon. saka ka na lang mamili ng unit na maganda. check for the ff na lang:
Ilang watts yung output nya?
ilang amp pwede ko ikabit?
may sub out ba?
I will retain the stock speakers first, connected to the HU directly. I will just use the preouts to connect to an amp then a sub, to add more bass. I will check how it sounds first.
Puwede ba 1 sub na lang, mga 8 or 10in? Wala naman distinction ang human ear sa low frequency ng left or right, tapos enclosed space naman ang kotse.
ako rin... have a question for my sound setup of REVO....
nagcanvass na kami last last week and pakicheck naman kung ok na ito for a simple boom boom or kung meron pa kayong suggestions baka mas makamura pa ako or get the same prices with much more quality..
the_wildthing::: pwede! ako gamit ko 10" sub lang in a 0.98 cu. ft box (sealed). i'm very satisfied with the bass. soft and ummpf enough for alternative tracks, gapang na rin for hip-hop/R&B tunes
Originally posted by mugen ako rin... have a question for my sound setup of REVO....
sa presyong ganyan, parang gusto ko na lang mag compVR na 12 or 15 na ported, instead of a pair of 15" targas na sealed.
mukhang mahal ang pyle na box and woofer. 10" lang sya tapos 7500. whereas kung i-compare mo sa 12" na kicker compvr, with box, 8,000 lang sya total. and i think everyone here will agree that a 12" kicker is worth more than 500 pesos above the 10" pyle. ang neon naman, for me, walang kwenta
Originally posted by luckytruck sa presyong ganyan, parang gusto ko na lang mag compVR na 12 or 15 na ported, instead of a pair of 15" targas na sealed.
its definitely better kicker yan eh. and in terms of power 12" is more powerful than a 10" sub.
I have a 2003 Super Grandia. Stock lahat nag speakers nun. CBU kasi ang sasakyan. 17 watts lang stock na speakers (all four). Tunog portable radio nga e.
What i did is to replace all four with Pioneers 4 inchers in front and 5's at the back. I paid 2100 lang yata for all the four speakers kasi may contact sa distributor. Anyways, the sound was a big improvement but it was lacking BASS. I was able to buy a brand new active subwoofer (Infinity Bass Link) for 15000. So far ok na tumunog but recently I saw a set of Infinity coax sa store. Mura lang din kaya pagiipunan ko na. Ang head unit ko ay stock na Kenwood In-dash 2023 yata ang model.
basta ba hindi siya ganu kakain ng space sa likudan eh... gusto ko pwede siya matanggal kapag kailangan ko ng space and kung di ko man tanggalin eh di naman ganu kain space sa likod...
salamat sa inputs... where could i get those 12" na kicker compvr with box?
