Results 41 to 50 of 574
Thread: Avanza Tires and Rims
January 3rd, 2010, 09:04 PM #41
Re: Avanza Tires and Rims
Sa harap, madaling i-lower ang avanza. mahirap sa likod. Kung minsan kasi ay talagang loaded ako ng pasahero, so hindi advisable na mag lowered.
Iyong outside diameter ng 205/55/R16 (na gamit ko) ay almost the same sa stock na 186/70/R14. So same lang ang fender gap.
Almost the same lang ang ride kasi noong stock 35 psi ang tire pressure ko. now 32 psi ang gamit ko.
Salamat. Hindi siya "bling" mags na prefer ko.
January 4th, 2010, 01:30 AM #42
January 4th, 2010, 01:32 AM #43
January 4th, 2010, 01:37 AM #44
January 4th, 2010, 01:39 AM #45
prefer ko sana ay 195/55/R16. Kaso ang hirap mag hanap. so nag 205/50/R16 ako. These two tires have almost the dame outside diameter. So hindi oversized nor undersized.
January 4th, 2010, 01:41 AM #46
January 4th, 2010, 09:34 AM #47
^^^sanay na ako sa sakit sa ulo.
post ko nalang kung sakali....hehehe
January 4th, 2010, 11:34 AM #48Verified Tsikot Member
- Mar 2009
- 142
nag iisip pa ako sa bibilhin ko mags kung ce28 bronze or torque na bronce 195/55/16 din prefer ko sir,ano bang meron lowering spring meron na available sa pinas? plan ko kahit 1.5 inch drop lang max na ang 2 inch... eibach spring daw e close to stock ride sa research ko
January 4th, 2010, 11:44 AM #49
Sa harap I think parang sa sedan ang set-up so madaling i-lower. Sa likod kasi ay may panhard. ito ang problem kaya mahirap i-lower sa likod.
January 4th, 2010, 01:23 PM #50Verified Tsikot Member
- Mar 2009
- 142
Thank you!
