Results 1,581 to 1,590 of 1618
July 26th, 2013, 01:40 PM #1581Verified Tsikot Member
- Feb 2012
- 21
Re: Avanza Periodic Maintenance Service (PMS)
Refrain from using "engine treatments" especially your car is still very new.
For fuel treatments, I suggest you get the STP Fuel Injector and Carburetor Treatment. The small bottle can be used for half filled tanks. I bought mine at P140 only. Here's the link: Carburetor Cleaner by STP® | Fuel Injector & Carburetor Treatment
July 30th, 2013, 12:47 AM #1582
- engine x1r treatment - P1120
- topgasz fuel tank treatment - P800
- sand paper, rags, & multi cleaner - P500
September 5th, 2013, 07:51 AM #1583Tsikot Member
- Dec 2010
- 3
Re: Avanza Periodic Maintenance Sevice (PMS)
Ask ko lang i got my 2013 Toyota Avanza last 2 weeks ago. 1000km na, Ano best time pumunta sa case para hinde ako masyadong matagal mag hintay
September 5th, 2013, 07:53 AM #1584
Set an appointment with your dealer nalang para di ka walk-in..
Sent from my GT-P7310 using Tapatalk 2
September 5th, 2013, 07:59 AM #1585Tsikot Member
- Dec 2010
- 3
Nagpa sked na ako kaso sabi puno daw kaya mag walk in na lang daw ako since first service daw. Kaya gusto ko malaman best time pumunta para sa walk in
September 5th, 2013, 12:23 PM #1586
September 28th, 2013, 04:39 PM #1587Verified Tsikot Member
- Feb 2012
- 21
Model: 2008 Avanza 1.3 J at 57,000 kms.
Periodic change oil and tune-up:
1) 3 liters Shell Helix HX7 5w-40 semi-synthetic motor oil at Php 304.00 /liter
2) Vic C110 oil filter at Php 225.00
3) Replacement air filter at Php 320.00
4) 4 pcs. Denso XU22EP-U spark plugs at Php 120.00 /pc. check this link: Original U-Groove | DENSO Auto Parts
5) Labor fee Php 350.00
Total: Php 2,287.00
November 28th, 2013, 01:36 AM #1588Verified Tsikot Member
- Aug 2012
- 9
Hi ask ko lang po kung magkano kaya aabutin ang 15K PMS? Thanks
www.teknogadyet.com
November 28th, 2013, 10:19 AM #1589
ordinary 5K interval PMS lang yan sir.. mga 2T+ lang yan
June 24th, 2014, 12:44 AM #1590Tsikot Member
- Feb 2013
- 2
May tao po ba dito. Hehe
high idle RPM at engine start
