Results 1,291 to 1,300 of 1618
April 12th, 2011, 04:15 AM #1291Tsikot Member
- Jan 2011
- 4
Re: Avanza Periodic Maintenance Service (PMS)
thanks po,,,,
pero sir qwerty,,, last pms nya po ay 10k,,
April 12th, 2011, 09:06 AM #1292
April 12th, 2011, 01:51 PM #1293
40T KM Check up - Use Fully Synthetic oil 1275
Toyota Brake Flud x2 310.36
TGFS, SM 5W40 L - x3 1647.33
Element S/A Oil Fltr - 357.02
Plug Spark x4 - 491.28
Gasket 25.25
TWWF W765 85.91
TSLC (2 Liters) 592.12
TGMG (GL-4 80W-90) 675.45
TGDG (GL-5 85W-90) 649.47
GREASE (Lubricant) 8.93
Brake Cleaner 199.37
Sand Paper 18
Package Wash 625
ATF 317.86
Miscel 60.26
Oring small 31.25
less discount labor -127.5
less discount parts -483.42
TWWF W765 85.91
Alin po kaya dito ang engine oil? at ilang liters po kaya. sa labas sana ako papa-PMS tapos bibili na lang ako ng orig TYT oil.
Plan ko po kasi sa petron na lang.
April 12th, 2011, 02:45 PM #1294
ito po yung engine oil. 3 liter po sa J and 3.2 liters of oil pag G.
April 12th, 2011, 04:52 PM #1295
April 12th, 2011, 06:36 PM #1296
This one, 5W40, Synthetic - Engine Oil
GL-4 80W-90, Synthetic Gear Lube for Rear Axle(Differential)
GL-5 85W-90, 'matic Gear OilLast edited by xda2jojo; April 12th, 2011 at 06:47 PM.
April 12th, 2011, 07:23 PM #1297
May na scanned ako from OM sir
http://www.avanzaclub.ph/forum/index...sg1952#msg1952
baka makatulong sayo
April 13th, 2011, 10:32 AM #1298
April 18th, 2011, 05:49 PM #1299Verified Tsikot Member
- Jan 2011
- 67
Toyota pasig allows outside orig oil. Pasig even allows imported OEM toyota oil filter. Innova oil filter is 90915-yzzd1(denso) or 90915-yzzg1(US). I am not sure about Avanza's filter but I found out Innova and Fortuner oil filters are the same. Tacoma 2.7L Engine is the same as the 2.7L Fortuner engine. Tacoma uses 90915-yzzd1 or 90915-yzzg1. Anyway, brought my own 6quarts of mobil 1 10w-30(5quart jug and 1 quart bottle) and IKH20 iridium plug from US for my 20K PMS INNOVA. Labor 1148, oil filter 426, drain plug gasket 28, misc 112 and sandpaper 25. Total P1740. I suggest you buy 5quart jug in walmart for $24 or a box for 6 quart in Costco wholesale for $34.
April 20th, 2011, 01:52 PM #1300Verified Tsikot Member
- Mar 2011
- 23
