Results 41 to 50 of 251
Thread: Avanza Engine Problem
June 27th, 2010, 12:55 PM #41
June 29th, 2010, 07:01 PM #42
Re: Avanza Engine Problem
ask lang din po mga Sir, bakit po? hindi po ba normal na mag fluctuates ang RPM pag bukas ang air-con natin? Newly owner lang po tayo ng Avanza and hindi ko rin po alam, napuna ko rin po yun sa RPM ko pag binubuksan ang AC, and dko rin alam if it is normal or hindi.... thanks.....[/quote]
my condition is not normal the rpm goes down lower than 500rpm halos mamatay na ang engine pagnaka idle at pagpinaandar mo naman kadalasan patay ang engine.
June 29th, 2010, 07:04 PM #43
June 29th, 2010, 07:08 PM #44
July 2nd, 2010, 09:31 PM #45
sa tingin ko mali ata un tawag ko sa nalinis ko (hindi servo), mali din ang tinutukoy ko na servo, sensya na hindi ko kasi kabisado ang parts ng makina, nakikinig lang ako sa mga mekaniko at electrician na kilala ko,kanina may nagsabi sa akin airvalve sensor daw iyon.
July 2nd, 2010, 10:48 PM #46
>>>parang may di naadjust ng maayos sa...wait lang hanapin ko muna sa baul ko.
>>>check mo lahat vacuum hose baka may bara,
>>>check mo din ang PCV(kulay green eto na katabi ng oil filler, na may tubo papuntang intake manifold) baka barado na rin, usually nyan pinapalitan but won't affect the idle at all.
you mean to say na kung mag accelarate ka, biglang babagsak ang rpm bos?
if so, may mali sa timing .
recheck ko muna mamaya avanza ko bos, as far as i know, aside sa sensor, may servo yan na tutulak or mag aadjust ng rpm sa tamang setting.
update ko eto mamaya...pauwi muna ako...
July 3rd, 2010, 12:33 PM #47
July 5th, 2010, 01:07 PM #48Verified Tsikot Member
- Aug 2008
- 51
Sir, Im having problems with my engine tingin ko pan belt, umiingit na sya every time na aangat ng 3k RPM ko, magkano kaya abutin palit pan belt? and san po kaya maganda magpagawa? antipolo side po ako thanks
July 5th, 2010, 01:42 PM #49
July 5th, 2010, 01:48 PM #50Verified Tsikot Member
- Aug 2008
- 51
Ahhhh, pano po i DIY yun? and ussualy ilan years po ba bago magpalit?
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
