Results 1 to 10 of 32
August 22nd, 2014 10:47 AM #1
How long do I have to wait before applying sealant or wax on a newly painted car or car panel?
- Nov 2013
- 2,077
- Jul 2008
- 485
August 22nd, 2014 05:04 PM #3
August 22nd, 2014 05:29 PM #4
Wow tagal pala.
What will happen if I put wax/sealant agad?
Posted via Tsikot Mobile App
August 22nd, 2014 06:05 PM #5
Our trusted pintor recommends 1 month ang pagpapatuyo
ng pintura bago i-final buffing ang anzhal paint.
he even said na mas okei kung ibilad mo kung gusto mo
mas mabilis ang pagpapatuyo.
kasi daw kahit tuyo na yung ibabaw,
yung mga layer sa ilalim nyan hindi pa gnun
katuyo kaparehas ng ibabaw.
hindi pa ako nakakakita ng incident ng nasirang pintura dahil sa
pagpahid ng kung ano sa body ng hindi pa fully tuyo ang paint,
pero i think ang possible scenario is sa kakapahid mo ng wax
or sa pag buff off nito, pwedeng sa diin ng kamay mo,
"mapunit" yung paint. lalo pa kaya kung DA polisher ang gamit.
August 23rd, 2014 06:00 PM #6
Copy sir. Balak ko kasing lagyan ng touchless sealant pero antay na muna mg one month. Ibabalik ko pa din for final buffing. May portion akong nakitang medyo hazy pa. DuPont daw pala ginamit.
August 23rd, 2014 06:29 PM #7
August 24th, 2014 01:24 AM #8
CarPro Hydro2.
Spray, Flood/Rinse, Dry.
Wala pa bang nakatry dito?
August 24th, 2014 01:49 AM #9
ah ok sir, ngayon ka lang narinig yang touchless sealant kahit sa pinoy detailing forums, parang wala pang gumamit niyan.
- Aug 2012
- 2,767
August 24th, 2014 08:19 AM #10iba lang way of application of CarPro Hydro2 but it is still a sealant and it will have bad effect on paint that is not yet cured. if you want to protect your new paint, you can put Pure Glaze product.
A common procedure for fresh paint is to hand or machine glaze the paint after any wetsanding, cutting and buffing has been performed.
Fresh Paint = Less than 30 days since it was sprayed
In most cases, fresh paint is sanded, buffed and glazed within a few days after being sprayed, before the owner picks up the car. For the glazing process you need to use a product that is "Body Shop Safe", that means there are no ingredients that will contaminate a fresh paint environment and cause surface adhesion problems for the new paint.
One type of surface adhesion problem is called "Fish Eyes" and that's where some type of contaminant remains on the prepped surface at the time the paint is sprayed and the surface tension created by the contaminant prevents paint from sticking to that area, so the paint pile up around the contaminated area and creates a circle without paint and because of the appearance after the paint dries, this type of defect has been given the name... "Fish Eye".
Two of the most well known Body Shop Safe glazes in the refinishing industry are
Meguiar's M07 Show Car Glaze
3M Imperial Hand Glaze
The backup charger finally arrived. Here are my findings and conclusion at the end:
