Page 120 of 392 FirstFirst ... 2070110116117118119120121122123124130170220 ... LastLast
Results 2,381 to 2,400 of 7833
    Jul 2010
    #2381
    Question lang mga gurus, may car wash na malapit sa min. Routine nila na maglagay ng quick detailer habang tinutuyo yung kotse. Ok ba yung ganung procedure nila? Another question is, pede ba ako mag apply ng wax kahit may existing na QD sa sasakyan. TIA
    Posted via Tsikot Mobile App
    Nov 2013
    #2382
    may store po ba ng meguiars dito sa pinas? ito po nabili ko sa Singapore, tingin ko mas mura ata dito, meron din dito Sonax at Autoglym.
    #2383
    Those are OTC products and available at Blade stores and Ace hardware.
    Aug 2010
    #2384
    Quote Originally Posted by boytsiks View Post
    Yes. Okay lang yun procedure na yun. Some people do it to cut down on time. The QD itself is diluted with the water and buffed once the drying/buffing procedure starts.
    Yes, however.. which QD are we talking about? If it's the likes of OCW, those are pretty much standalone waxes in their own right so "topping" it might seem of a waste (best to let it be your LSP and simply wear it down). QDs are usually designed to be the last application layer to complement the wax/sealant beneath it. However wala naman problema in "layering" it as long as the wax you're using is pure wax -- no cleaners.
    Quote Originally Posted by sword View Post
    Yes. Meguiars has an extensive distribution network sa Philippines and is expensive actually. If you want relatively affordable Megs, start importing some from the United States.
    Jan 2014
    #2385
    b) Collinite 476s (~P700 at autobisyo): Paste wax. Hard to remove if multiple panels are allowed to set before buffing. One of the most durable waxes locally available. Able to resist a couple of weeks of rain or several washes before fading away.
    Question lang po regarding the quoted text from first page. Hard to remove, that means po ba na hirap sya ibuff if nag-apply ka ng wax sa buong kotse instead na per panel?
    2nd question po, what's the best glaze for a dark red car? (carnelian red civic fb) i'm leaning towards to Mothers Step 2 pero baka may marecommend kayong mas maganda
    thanks tsikot!
    #2386
    Eto mga nasubukan ko so far.
    Poorboys blackhole
    CG Blacklight
    CG EZ Creme Glaze
    These are excellent sa dark colored cars.
    Oct 2003
    #2387
    ang gusto ko ngayon is Liquid Glass. ganda rin on black cars.
    Aug 2013
    #2388
    any suggestion kung anung magandang combo sa dalawang ito.. collonite 476s at nxt.. meron na kasi ako nitong dalawa. pero hindi ko alam kung anu unahin ko.. nxt muna then collonite or vice versa?.. do i need to buy meg compound?..
    my car is honda jazz taffeta white.. gusto ko sana maging malinis tignan at makinis talaga. thanks po .. i appreciate your reply
    Aug 2010
    #2389
    Quote Originally Posted by Anakid View Post
    Malinis tignan is a matter of keeping the paint imperfection-free. This means -- a clean car, if possible.. one that's waxed and not oxidized enough to be seen through the paint.
    Makinis is more of keeping your paint leveled -- less scratches, the better.
    For the Collinite 845 and the NXT. Just use and pick one. Don't bother with layering -- the benefits is.. uhh... slim really.
    Aug 2010
    #2390
    Quote Originally Posted by nikolodeon View Post
    thanks tsikot!
    Yes. If you apply it first to the entire car -- leaving the panel to cure a long time, buffing the 476 will be a pain in the ass. You'll be using a lot of elbow grease so it's best to get your rotary in case you plan on going this route. Best application of the 476 will still be on a panel-basis when applying by hand. Remember to apply lightly!
    For the second question, I will have to pass. I'm not a general fan of glazes particularly. To let your red paint "pop", it's best to simply prep the paint surface throughly. This means paint correction when you need it, clean the surface of the car to remove any leftover waxes or impurities, and layering down the LSP whether it be a sealant or wax.
    Aug 2013
    #2391
    Paano alisin bird droppings? Is it OK to spot clean with carwash solution then no more rinse (condo kasi parking ko). I've heard about optimum no rinse (ONR) but I can't seem to find it in the mall auto stores and hardware stores.
    Thanks!
    Richard
    Aug 2009
    #2392
    Have you checked online vendors for ONR? You can arrange for shipping or meet-up depending on the seller's conditions.
    Aug 2013
    #2393
    Quote Originally Posted by Calistro View Post
    Got one from a sulit seller.
    Thanks!
    Aug 2013
    #2394
    Quick question. Puwede ko bang gamitin yung Aquazorb MF towel na pang tao (Aquazorb) to dry my car after using ONR? Wala kasi akong makitang large enough na drying towel and this seems to be even cheaper per sq. ft. that those for car use. I have one lying around which I don't like to use due to its weird "feel".
    Apr 2012
    #2395
    Quote Originally Posted by Pao11 View Post
    malamang pwede yan kasi microfiber naman. as long as malambot at absorbent saka hindi mag-cause ng swirls ay pwede yan ;)
    #2396
    Ingat lang sa pag linis ng MF towels, huwag gamitan ng detergent o fabric conditioner, tumitigas daw at nakakagasgas ng paint. Joy o Perla daw ang maganda. Meron din daw cleaners talaga na pang MF. Pero ako Joy at Perla lang nagagamit ko.
    Feb 2014
    #2397
    Guys, ano bang pwedeng pang linis sa ceiling natin? Or mas okay ba na ipa service ko nalang? TIA
    #2398
    Quote Originally Posted by loverlionus View Post
    I have about 80 microfiber towels and washmitts. I use breeze detergent for the wash and vinegar for the final rinse. Yes, Perla is good for microfiber pero mahal sha and sometimes do not remove stains in the towel.
    The key in maintaining microfiber towels soft is in the way you dry them. If you hang them and let them air dry natirally, mag bubuhol buhol/dikit dikit yung fibers. Let them dry in a dryer at low temperature setting. They will come out soft and the fibers will not be tangled.
    #2399
    Sir, out of topic down ang site ng PDC?
    #2400
    Hi All,
    I am a student currently doing research for my marketing thesis paper. I am trying to understand the automotive car paint industry. Hope you all can help me :-) Sobrang mabilis lang ito, total of 15s questions
    Link --
    Please refer to this online link.
    PART 1: https://www.surveymonkey.com/s/2GJ7VMC
    PART 2: https://www.surveymonkey.com/s/2GHLQL7
    Thanks
"Tamang OC lang" - a newbie's guide to car appearance maintenance
