Results 2,711 to 2,720 of 7833
- Aug 2012
- 2,767
October 24th, 2014 08:38 AM #2711
- Mar 2014
- 33
October 24th, 2014 08:50 AM #2712
- Aug 2012
- 2,767
October 24th, 2014 11:04 AM #2713^yes, you can use rubbing compound for testing. mas aggressive nga lang siya kaysa polish.
- Mar 2014
- 33
- Aug 2012
- 2,767
October 29th, 2014 09:23 PM #2716
* bro red_one
since your active in this thread that states that you know alot about
paints and detailing
May I ask you
what's the difference of faded paint and oxidated paint and
how will I know if it's faded or oxidated?
- Aug 2012
- 2,767
October 30th, 2014 03:16 PM #2717Faded paint looks dull or dim.
Oxidized paint looks dull and cloudy/hazy. Some may also show sign of clear coat failure.
Faded paint and oxidized paint can be fixed by compounding and/or polishing.
Clear coat failure can only be fixed by repainting the panel. The problem is already IN the paint, not only ON the paint surface.
Faded paint. BEFORE and AFTER paint correction:
Oxidized paint. BEFORE and DURING paint correction:
Clear coat failure. Clear coat has turned white and started to flake off:
October 30th, 2014 04:12 PM #2718
- Aug 2012
- 2,767
October 30th, 2014 05:35 PM #2719*crosswind: It is hard to see in the photo as i can see the reflection of the car cover on the paint.
Oxidation is more common to single-stage paint system while clear coat failure is more common to two-stage paint system. Generally, oxidation will cover the whole panel while clear coat failure can either affect small areas or the whole panel.
Causes of clear coat failure:
1. Thin clear coat (wet sanded too far)
2. Frequent sun exposure
3. No protection -- wax/sealant (most common reason)
4. Paint has dried out
Here's a car that shows early stage of clear coat failure. The middle area of the hood is becoming cloudy/hazy but not yet flaking or peeling off.
October 30th, 2014 07:20 PM #2720
i think its not even a case of fading and oxidation, but i see watermarks that already etched on the paint. compounding and polishing/finishing may remedy the problem. i think kaya yan ng M105/M205 combo. an application of sealant after will protect the paint from further damage.
